March 17, 20179 yr I am trying to use this switch in a motion based program. It is a switch module that turns a normal switch into a smart switch. The issue I am having is overriding the motion turning off the switch when I manually turn it on. I see that this module can report the switch position but only if you set the configuration parameter of 3 to 1. When I try this I get two blank error popups and the configuration parameter is not saved. Not helpful. Any ideas? Thanks
