Scottmichaelj Posted April 11, 2017 Share Posted April 11, 2017 If I unsderstand well your point, that means the trigger would be an open or close garage door (through the GDO and the IOlinc ). But I only want to open an Insteon light device with a free Homelink button, without having to open or close the garage door.No Homelink button in the car mirror connects the the 635 GDO. The button "triggers" the IOLinc and then trigger any programs/scenes/lights you want. Edit: Basically your pretending you have another GDO but you don't. Link to comment Share on other sites More sharing options...
jacmath Posted April 11, 2017 Author Share Posted April 11, 2017 Great Scott !! Thanks for your help and sorry for my misunderstanding. I will explore that route then. Jack Link to comment Share on other sites More sharing options...
jacmath Posted April 14, 2017 Author Share Posted April 14, 2017 Another thoughtIf I wanted to use the third homelink button of my car to do another similar but unrelated task, would I absolutely need another kit (635lm-i/o link) ? thanks Jack Link to comment Share on other sites More sharing options...
Scottmichaelj Posted April 14, 2017 Share Posted April 14, 2017 Another thought If I wanted to use the third homelink button of my car to do another similar but unrelated task, would I absolutely need another kit (635lm-i/o link) ? thanks Jack Yes because that IOLinc is specific to that GDO/Homelink button. It wouldnt know the difference between buttons. Then you start to run out of Homelink buttons bc the most I have seen in any car is three. Link to comment Share on other sites More sharing options...
marcin Posted April 21, 2017 Share Posted April 21, 2017 Hopefully this weekend I will take some pictures of my set up, so you have a better idea. Link to comment Share on other sites More sharing options...
Scottmichaelj Posted April 22, 2017 Share Posted April 22, 2017 Hopefully this weekend I will take some pictures of my set up, so you have a better idea.What cuz my post #24 on 06/18/15 is too hard to understand? Or because I didn't include pictures? Oh pix you say? My program is posted there too. Edit: Want to make sure you know I am joking hence the Link to comment Share on other sites More sharing options...
jacmath Posted April 26, 2017 Author Share Posted April 26, 2017 Hi I'm having the exact same setup in my garage just next to the door. I've paired one of my liftmaster remote with the 635lm and wrote two simple programs that can open and close my external lights with my isy. Then, I have paired the remote with one homelink button in my car. The car is only a few feet away frome the garage door. I followed the same procedure of pairing the homelink button as I did with the other one wich open and close the garage door. The problem : With the liftmaster remote in the car, I can open the external lights, but with the homelink paired button it's not working, even if I open the garage door. Any idea of a solution ? Thanks Jack Link to comment Share on other sites More sharing options...
