ISY Portal Setting for iRule Gateway
Been trying to figure out how to get iRule to control my ISY via the portal.  Here are my thoughts so far:
For the Gateway Configuration:
Type: HTTP
Name: My ISY Portal
IPv4 Address: my.isy.io
Port: 443
Username: Name%40domain.com
Password: ********
HTTP Method: Get
In the panel, I've set a variable on entrance $URLPrefix$ on the panel equal to the prefix in the Portal URL to ISY:
/isy/aabbccddee....112233445566
No love.  I can access directly via IP address without the prefix.
Thoughts?
I don't know much iRule, but you seem to be doing it right.
I think the issue is that it is trying to do straight HTTP over port 443. You need to use HTTPS.
This is an excerpt from the support page:
If your IP address or URL require Secure socket connection, you simply put HTTP:// in front of the IP address or URL (https://192.168.0.69)
Benoit.
