Lexicon and naming convention
Are there any published naming conventions for controlling ISY via Alexa or Google?
Choosing your ISY device names/scenes/groups carefully is important, especially if you want to avoid having Alexa excessively yuck at you if she detects conflicts.
For the most part, I setup insteon scenes and assign those to the portal. Before the portal, I used a web app I wrote (it has a forum here) that you could turn scenes on and off. Adding them to the portal was a snap, and within 5 minutes I was able to control every scene from Alexa. However I had lots of conflicts due to the ISY names I chose. Eventually I found the following works pretty well.
<Location><scene/device>
(blank) fan
master fan
den fan
Alexa turn fan on (turns on family room fan. Note I left the location blank, as we use this a lot)
Alexa turn den fan off
Alexa turn master fan on
However I have to be careful of other devices not controlled by the ISY. For example, I have the Harmony hub which turns on my TV, receiver, cable box, etc. So with the following commands, Alexa gets confused. I have no idea why.
Alexa turn on TV (Executes a harmony scene)
Alexa turn on TV LIGHTS (Executes an ISY scene)
My only solution was to change TV LIGHTS to MOVIE LIGHTS.
Using Alexa, I haven't found a foolproof convention. Perhaps Google does a better job.
