Web Power Switch 7
Yes, but I have since moved it to a RTI XP.
Sent from my Nexus 6P using Tapatalk
DLI WPS7s are great product. Can you post the url and what your trying to do? For example power on switch 4.
Can't really get it to do anything... I just want basic controls... not sure if the Rest API is the right approach or not...
Can't figure out how to authenticate myself? I try:
http://admin:XX@192.168.1.xxx
in a browser and it just redirects me to the login page.
I tried the curl example from the documentation:
curl -H "Range: dli-depth=1" -H "Accept: application/json" --digest 'http://admin:xxx@192.168.1.xxx/restapi/'
and I just get back:
<HTML><HEAD>
<META HTTP-EQUIV="refresh" content="0; URL=/">
</HEAD><BODY></BODY>
You do a GET request for
/outlet?7=ON
/outlet?7=OFF
/outlet?7=CCL
You have to put
Authorization: Basic [token]
in the header where [token] is the Base64 of the USERNAME:PASSWORD
You can't do username:password in modern browsers as that feature was removed a log time ago.
Also, the Power Switch 7 does not support the restapi.
Edited by Gary Funk
Ah perfect that worked! Also it didn't help matters that the outlet I was testing and I thought was empty was actually controlling my ISY :)
Lol oops! Glad Gary got you sorted out. Also look at "auto ping" [emoji3]
Thanks, I've used the "auto ping" feature when I used to have some web cam that's would get stuck and then I would power cycle them as needed.
I wanted to set this up in the ISY to I can use the Echo for control over the switches.
[emoji1303]
