used the replace with another device a 6 button with an 8 button
now I only have 5 nodes on it instead of 8, how do I get my other 3 keys back?
When you do a replace device it has to be like for like.
You'll need to delete the device, do a factory reset on the device,  then reinstall it
I was afraid that would be the case!
A factory reset will bring the KPL to its default state. Which was the original KPL, 6 or 8-button? Did you ever change the original from one mode to the other mode? What is the replacement? Provide model numbers.
