Keypad linc dimmer won't program
I have a keypad linc dimmer (2486D, 6 button, v39) that I can't get a button programmed on. The ISY says it has successfully added the button to a scene but the button doesn't turn on the in-line switch it was linked too in the scene.
Did you add the button as a Controller?
If not, then delete it from the scene and add it back in.
