Weather Station Compatibility
I am thinking about installing a weather station in my home and was wondering if hte ACURITE (model #: 01022M) weather station is compatible with the ISY and Insteon network.  Will I be able to create programs to trigger Insteon devices to to turn off and on.
Thank you
Does this hardware offer a means to connect to the system and retrieve the data via a open API? Whether that be a web scrape, polling, push connection from the hardware itself? [emoji848]
Thank you
Order a WeatherFlow Smart Weather Station.
Sent from my SM-G955U1 using Tapatalk
