Nodelink and Entry Delay
Hi io_guy,
I just discovered that since switching to Nodelink, entry delay no longer becomes true during an entry delay.  Not sure if you need it, but verbose log below:
2017-08-29 19:52:03 - Alarm: Virtual Keypad Update (01,8C08,08,00,ARMED ***STAY***                $) [hwalrm1]
2017-08-29 19:52:05 - TCP: Data Received - 76 Bytes [hwalrm1]
2017-08-29 19:52:05 - TCP: %02,0703000000000000$[C][L]%00,01,8C08,08,05,DISARM SYSTEM   or alarm occurs $[C][L] [hwalrm1]
2017-08-29 19:52:05 - Alarm: Partition State Change [hwalrm1]
2017-08-29 19:52:05 - Alarm: Virtual Keypad Update (01,8C08,08,05,DISARM SYSTEM   or alarm occurs $) [hwalrm1]
2017-08-29 19:52:06 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-29 19:52:06 - TCP: %00,01,8C08,08,05,DISARM SYSTEM   or alarm occurs $[C][L] [hwalrm1]
2017-08-29 19:52:16 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-29 19:52:16 - TCP: %00,01,8C08,08,05,DISARM SYSTEM   or alarm occurs $[C][L] [hwalrm1]
2017-08-29 19:52:16 - Alarm: Virtual Keypad Update (01,8C08,08,05,DISARM SYSTEM   or alarm occurs $) [hwalrm1]
2017-08-29 19:52:24 - TCP: %00,01,8C08,08,04,DISARM SYSTEM   or alarm occurs $[C][L] [hwalrm1]
2017-08-29 19:52:24 - Alarm: Virtual Keypad Update (01,8C08,08,04,DISARM SYSTEM   or alarm occurs $) [hwalrm1]
2017-08-29 19:52:26 - TCP: Data Received - 76 Bytes [hwalrm1]
2017-08-29 19:52:26 - TCP: %02,0103000000000000$[C][L]%00,01,1C08,08,01,LOWER             Ready to Arm  $[C][L] [hwalrm1]
2017-08-29 19:52:26 - Alarm: Partition State Change [hwalrm1]
2017-08-29 19:52:26 - Alarm: Virtual Keypad Update (01,1C08,08,01,LOWER             Ready to Arm  $) [hwalrm1]
2017-08-29 19:52:29 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-29 19:52:29 - TCP: %00,01,1008,CA,20,Alarm Canceled                  $[C][L] [hwalrm1]
2017-08-29 19:52:29 - Alarm: Virtual Keypad Update (01,1008,CA,20,Alarm Canceled                  $) [hwalrm1]
2017-08-29 19:52:31 - TCP: Data Received - 76 Bytes [hwalrm1]
2017-08-29 19:52:31 - TCP: %02,0303000000000000$[C][L]%00,01,0C08,08,00,LOWER           Hit * for faults$[C][L] [hwalrm1]
2017-08-29 19:52:31 - Alarm: Partition State Change [hwalrm1]
2017-08-29 19:52:31 - Alarm: Virtual Keypad Update (01,0C08,08,00,LOWER           Hit * for faults$) [hwalrm1]
2017-08-29 19:52:31 - TCP: Polling Alarm [hwalrm1]
2017-08-29 19:52:31 - TCP: Data Received - 9 Bytes [hwalrm1]
2017-08-29 19:52:31 - TCP: ^00,00$[C][L] [hwalrm1]
2017-08-29 19:52:32 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-29 19:52:32 - TCP: %00,01,0008,CA,20,Alarm Canceled                  $[C][L] [hwalrm1]
2017-08-29 19:52:32 - Alarm: Virtual Keypad Update (01,0008,CA,20,Alarm Canceled                  $) [hwalrm1]
2017-08-29 19:52:37 - TCP: Data Received - 76 Bytes [hwalrm1]
2017-08-29 19:52:37 - TCP: %02,0103000000000000$[C][L]%00,01,1C08,08,00,LOWER             Ready to Arm  $[C][L] [hwalrm1]
2017-08-29 19:52:37 - Alarm: Partition State Change [hwalrm1]
2017-08-29 19:52:37 - Alarm: Virtual Keypad Update (01,1C08,08,00,LOWER             Ready to Arm  $) [hwalrm1]
(The 'Alarm Canceled' status in this is just because I armed and disarmed in under 2 mins.)
I'd appreciate it if you could take a look, please let me know if there's anything else you need from me.
Thanks!!
Chris
Does NodeLink properly see the partition as armed away?
Yep, armed away/stay/night stay all work fine.
Can you enable the verbose logging on the Main NodeLink page and post the log of toggled armed/disarmed again?
Hi io_guy, see below.  I included from 2 seconds before arm, through entry delay, and then disarm.  Note there is partition 2 stuff mixed in there as well, but I didn't remove anything as it was tough to tell what lines went with which partitions.
Thanks again for looking into this!!
2017-08-30 10:45:25 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 7)
2017-08-30 10:45:25 - ISY: Variable hwalrm1_part1-GV5 replaced in queue (Val: 0, QS: 7)
2017-08-30 10:45:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:25 - ISY: Variable hwalrm1_part1-GV4 replaced in queue (Val: 0, QS: 6)
2017-08-30 10:45:25 - ISY: Variable hwalrm1_part1-GV1 replaced in queue (Val: 0, QS: 6)
2017-08-30 10:45:25 - ISY: Variable hwalrm1_part1-ST replaced in queue (Val: 1, QS: 6)
2017-08-30 10:45:25 - ISY: Variable hwalrm1-ST replaced in queue (Val: 1, QS: 6)
2017-08-30 10:45:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/1/25)
2017-08-30 10:45:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/1/25)
2017-08-30 10:45:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:25 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:25 - TCP: %00,01,8008,02,00,ARMED ***STAY***May Exit Now  02$[C][L] [hwalrm1]
2017-08-30 10:45:25 - Alarm: Virtual Keypad Update (01,8008,02,00,ARMED ***STAY***May Exit Now  02$) [hwalrm1]
2017-08-30 10:45:25 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:26 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:26 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:26 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:26 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:26 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 1, QS: 5)
2017-08-30 10:45:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:26 - ISY: Variable hwalrm1-ST added to queue (Val: -1, QS: 5)
2017-08-30 10:45:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/1/25)
2017-08-30 10:45:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-08-30 10:45:26 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:26 - TCP: %00,01,8008,01,00,ARMED ***STAY***May Exit Now  01$[C][L] [hwalrm1]
2017-08-30 10:45:26 - Alarm: Virtual Keypad Update (01,8008,01,00,ARMED ***STAY***May Exit Now  01$) [hwalrm1]
2017-08-30 10:45:26 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 5)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 1, QS: 6)
2017-08-30 10:45:27 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:27 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 6)
2017-08-30 10:45:27 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:27 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:27 - TCP: %00,02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $[C][L] [hwalrm1]
2017-08-30 10:45:27 - Alarm: Virtual Keypad Update (02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $) [hwalrm1]
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 7)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS:
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 9)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 10)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 11)
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 12)
2017-08-30 10:45:27 - ISY: Variable hwalrm1-ST replaced in queue (Val: -1, QS: 12)
2017-08-30 10:45:27 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:27 - TCP: %00,01,8C08,08,00,ARMED ***STAY***                $[C][L] [hwalrm1]
2017-08-30 10:45:27 - Alarm: Virtual Keypad Update (01,8C08,08,00,ARMED ***STAY***                $) [hwalrm1]
2017-08-30 10:45:27 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 12)
2017-08-30 10:45:28 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 13)
2017-08-30 10:45:28 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 14)
2017-08-30 10:45:28 - ISY: Variable hwalrm1_part1-GV4 replaced in queue (Val: 0, QS: 14)
2017-08-30 10:45:28 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:28 - ISY: Variable hwalrm1_part1-GV1 replaced in queue (Val: 0, QS: 13)
2017-08-30 10:45:28 - ISY: Variable hwalrm1_part1-ST replaced in queue (Val: 1, QS: 13)
2017-08-30 10:45:28 - ISY: Variable hwalrm1-ST replaced in queue (Val: 1, QS: 13)
2017-08-30 10:45:28 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:28 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/1/25)
2017-08-30 10:45:28 - ISY: Variable caiwc1-ST added to queue (Val: 1, QS: 12)
2017-08-30 10:45:28 - ISY: Variable caiwc1_t5-ST added to queue (Val: 72.6, QS: 13)
2017-08-30 10:45:28 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/1/25)
2017-08-30 10:45:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-08-30 10:45:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-08-30 10:45:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-08-30 10:45:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-08-30 10:45:29 - ISY: Variable ecobee-GV2 added to queue (Val: 1, QS: 9)
2017-08-30 10:45:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-08-30 10:45:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-08-30 10:45:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-08-30 10:45:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc1/report/status/ST/1/25)
2017-08-30 10:45:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc1_t5/report/status/ST/72.6/25)
2017-08-30 10:45:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ecobee/report/status/GV2/1/25)
2017-08-30 10:45:31 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:31 - TCP: %00,02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $[C][L] [hwalrm1]
2017-08-30 10:45:31 - Alarm: Virtual Keypad Update (02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $) [hwalrm1]
2017-08-30 10:45:31 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:31 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:31 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:31 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:31 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-08-30 10:45:31 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:31 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 5)
2017-08-30 10:45:31 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:31 - ISY: Variable hwalrm1-ST added to queue (Val: -1, QS: 7)
2017-08-30 10:45:31 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-08-30 10:45:31 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-08-30 10:45:31 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-08-30 10:45:31 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-08-30 10:45:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-08-30 10:45:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-08-30 10:45:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-08-30 10:45:32 - TCP: Data Received - 76 Bytes [hwalrm1]
2017-08-30 10:45:32 - TCP: %02,0703000000000000$[C][L]%00,01,8C08,08,05,DISARM SYSTEM   or alarm occurs $[C][L] [hwalrm1]
2017-08-30 10:45:32 - Alarm: Partition State Change [hwalrm1]
2017-08-30 10:45:32 - Alarm: Virtual Keypad Update (01,8C08,08,05,DISARM SYSTEM   or alarm occurs $) [hwalrm1]
2017-08-30 10:45:32 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:33 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:33 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:33 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:33 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:33 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 1, QS: 5)
2017-08-30 10:45:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:33 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 5)
2017-08-30 10:45:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/1/25)
2017-08-30 10:45:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/1/25)
2017-08-30 10:45:34 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:34 - TCP: %00,01,8C08,08,05,DISARM SYSTEM   or alarm occurs $[C][L] [hwalrm1]
2017-08-30 10:45:34 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:34 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:34 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:34 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:34 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:34 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:34 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 1, QS: 5)
2017-08-30 10:45:34 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:34 - ISY: Variable hwalrm1-ST added to queue (Val: -1, QS: 5)
2017-08-30 10:45:34 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:34 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:34 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:35 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/1/25)
2017-08-30 10:45:35 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-08-30 10:45:35 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:35 - TCP: %00,02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $[C][L] [hwalrm1]
2017-08-30 10:45:35 - Alarm: Virtual Keypad Update (02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $) [hwalrm1]
2017-08-30 10:45:35 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:35 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:35 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:35 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:35 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-08-30 10:45:35 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:35 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 5)
2017-08-30 10:45:35 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:35 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 7)
2017-08-30 10:45:35 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-08-30 10:45:35 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-08-30 10:45:35 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-08-30 10:45:35 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-08-30 10:45:36 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-08-30 10:45:36 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-08-30 10:45:36 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/1/25)
2017-08-30 10:45:39 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:39 - TCP: %00,02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $[C][L] [hwalrm1]
2017-08-30 10:45:39 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:39 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:39 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:39 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-08-30 10:45:39 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:39 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:39 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 5)
2017-08-30 10:45:39 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:39 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-08-30 10:45:39 - ISY: Variable hwalrm1-ST added to queue (Val: -1, QS: 6)
2017-08-30 10:45:39 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-08-30 10:45:39 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-08-30 10:45:39 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-08-30 10:45:40 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-08-30 10:45:40 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-08-30 10:45:40 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-08-30 10:45:43 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:43 - TCP: %00,02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $[C][L] [hwalrm1]
2017-08-30 10:45:43 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:43 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-08-30 10:45:43 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:43 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:43 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:43 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:43 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-08-30 10:45:43 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 4)
2017-08-30 10:45:43 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 5)
2017-08-30 10:45:43 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 6)
2017-08-30 10:45:43 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-08-30 10:45:43 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-08-30 10:45:43 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-08-30 10:45:44 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-08-30 10:45:44 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-08-30 10:45:44 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:44 - TCP: %00,01,8C08,08,05,DISARM SYSTEM   or alarm occurs $[C][L] [hwalrm1]
2017-08-30 10:45:44 - Alarm: Virtual Keypad Update (01,8C08,08,05,DISARM SYSTEM   or alarm occurs $) [hwalrm1]
2017-08-30 10:45:44 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:44 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:44 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:44 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 5)
2017-08-30 10:45:44 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:44 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 1, QS: 7)
2017-08-30 10:45:44 - ISY: Variable hwalrm1-ST replaced in queue (Val: -1, QS: 7)
2017-08-30 10:45:44 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/1/25)
2017-08-30 10:45:45 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-08-30 10:45:45 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:45 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:45 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:45 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:45 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:45 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/1/25)
2017-08-30 10:45:46 - TCP: Data Received - 76 Bytes [hwalrm1]
2017-08-30 10:45:46 - TCP: %02,0103000000000000$[C][L]%00,01,1C08,08,01,LOWER             Ready to Arm  $[C][L] [hwalrm1]
2017-08-30 10:45:46 - Alarm: Partition State Change [hwalrm1]
2017-08-30 10:45:46 - Alarm: Virtual Keypad Update (01,1C08,08,01,LOWER             Ready to Arm  $) [hwalrm1]
2017-08-30 10:45:46 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:46 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 1, QS: 2)
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 5)
2017-08-30 10:45:47 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 0, QS: 5)
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part1-GV3 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:47 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 7)
2017-08-30 10:45:47 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/1/25)
2017-08-30 10:45:47 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:47 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:47 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:47 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:47 - TCP: %00,02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $[C][L] [hwalrm1]
2017-08-30 10:45:47 - Alarm: Virtual Keypad Update (02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $) [hwalrm1]
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 5)
2017-08-30 10:45:47 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:48 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 7)
2017-08-30 10:45:48 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS:
2017-08-30 10:45:48 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 9)
2017-08-30 10:45:48 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 10)
2017-08-30 10:45:48 - ISY: Variable hwalrm1-ST replaced in queue (Val: -1, QS: 10)
2017-08-30 10:45:48 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/0/25)
2017-08-30 10:45:48 - Relay Server: Running program (/home/pi/honlink/alarmvoices/alarmvocal.sh)
2017-08-30 10:45:48 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV3/0/25)
2017-08-30 10:45:48 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-08-30 10:45:48 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-08-30 10:45:48 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-08-30 10:45:48 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-08-30 10:45:48 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-08-30 10:45:49 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-08-30 10:45:49 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-08-30 10:45:49 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-08-30 10:45:50 - TCP: Data Received - 76 Bytes [hwalrm1]
2017-08-30 10:45:50 - TCP: %02,0303000000000000$[C][L]%00,01,0C08,08,00,LOWER           Hit * for faults$[C][L] [hwalrm1]
2017-08-30 10:45:50 - Alarm: Partition State Change [hwalrm1]
2017-08-30 10:45:50 - Alarm: Virtual Keypad Update (01,0C08,08,00,LOWER           Hit * for faults$) [hwalrm1]
2017-08-30 10:45:50 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 1)
2017-08-30 10:45:50 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 2)
2017-08-30 10:45:50 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 3)
2017-08-30 10:45:50 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 4)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 5)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 0, QS: 6)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part1-GV3 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:51 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 7)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:51 - TCP: Data Received - 53 Bytes [hwalrm1]
2017-08-30 10:45:51 - TCP: %00,02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $[C][L] [hwalrm1]
2017-08-30 10:45:51 - Alarm: Virtual Keypad Update (02,0008,07,00,FAULT 07 FRONT  DOOR UPPER      $) [hwalrm1]
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 5)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 6)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 7)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 7)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS:
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 9)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 10)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/0/25)
2017-08-30 10:45:51 - ISY: Variable hwalrm1-ST replaced in queue (Val: -1, QS: 9)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV3/0/25)
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-08-30 10:45:51 - TCP: Data Received - 70 Bytes [hwalrm1]
2017-08-30 10:45:51 - TCP: %03,1441010020$[C][L]%00,01,0008,CA,20,Alarm Canceled                  $[C][L] [hwalrm1]
2017-08-30 10:45:51 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-08-30 10:45:51 - Alarm: Virtual Keypad Update (01,0008,CA,20,Alarm Canceled                  $) [hwalrm1]
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 7)
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS:
2017-08-30 10:45:51 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 9)
2017-08-30 10:45:52 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 10)
2017-08-30 10:45:52 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 11)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-08-30 10:45:52 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 0, QS: 11)
2017-08-30 10:45:52 - ISY: Variable hwalrm1_part1-GV3 added to queue (Val: 0, QS: 12)
2017-08-30 10:45:52 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 13)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-08-30 10:45:52 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-08-30 10:45:53 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-08-30 10:45:53 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-08-30 10:45:53 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/0/25)
2017-08-30 10:45:53 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV3/0/25)
2017-08-30 10:45:53 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/1/25)
All your arms are arm-stay.  The entry delay will only trigger when it's an arm-away.
Could add it to stay as well, looking at the code it doesn't appear HonLink had this either.
Ahhhh...I just assumed it was true whenever the system went into 'Disarm System Now' mode. That explains how I never noticed it, I thought I was going crazy for a bit wondering how I could possibly have not realized this before - but I just started leaving one my dogs out during the day while I'm not home, and am using arm stay to avoid the motions for now.  He doesn't trigger them yet, but he's still has a little bit of growing left to do, and I don't want him to suddenly tip the scales one day while I'm away and trip them!
At any rate, if you could add it that would be greatly appreciated.  I can still separate an entry delay from away vs stay based on a combo of entry delay and arm state...so no harm in doing so, but more flexibility (and will fix my issue!!).
Thank you so much!!
