Ecobee not updating due to a bad sensor data value = "unknown".
In the log I'm receiving:
Ecobee Timer Error - Conversion from string "unknown" to type 'Single' is not valid
Which I believe is causing nodelink to not report any sensor correctly that comes after this. In ISY I have a "Sensor 9" that doesn't get any information or named correctly.
The "basement" sensor (a bad sensor used for testing) doesn't report any temperature values which is causing an "unknown" value to be returned in the API. I assume since sensor 9 comes after this in the results, the exception is causing it to be skipped over.
2017-09-05 13:21:21 - ISY NodeLink Server v0.7.1 started
2017-09-05 13:21:21 - Mono version: 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4)
2017-09-05 13:21:21 - ISY resolved to 10.0.1.10
2017-09-05 13:21:21 - Web config server started (http://10.0.1.226:8090)
2017-09-05 13:21:22 - ISY Node Server config detected (profile 5)
2017-09-05 13:21:22 - Auto-Update: Checking for program update...
2017-09-05 13:21:23 - Auto-Update: No web update available
2017-09-05 13:21:24 - Ecobee: New tokens received from ecobee.com [ecobee1]
2017-09-05 13:21:24 - Ecobee Data: {
  "thermostatCount": 1,
  "revisionList": [
    "311042349621:Thermostat:true:170905135949:170902162150:170905171929:170905170500"
  "statusList": [
    "311042349621:compCool1,fan"
  "status": {
    "code": 0,
    "message": ""
} [ecobee1]
  "page": {
    "page": 1,
    "totalPages": 1,
    "pageSize": 1,
    "total": 1
  "thermostatList": [
      "identifier": "311042349621",
      "name": "Thermostat",
      "thermostatRev": "170905135949",
      "isRegistered": true,
      "modelNumber": "athenaSmart",
      "brand": "ecobee",
      "features": "HomeKit",
      "lastModified": "2017-09-05 13:59:49",
      "thermostatTime": "2017-09-05 13:21:24",
      "utcTime": "2017-09-05 17:21:24",
      "alerts": [],
      "settings": {
        "hvacMode": "cool",
        "lastServiceDate": "2017-05-17",
        "serviceRemindMe": false,
        "monthsBetweenService": 6,
        "remindMeDate": "2017-05-17",
        "vent": "off",
        "ventilatorMinOnTime": 20,
        "serviceRemindTechnician": false,
        "eiLocation": "",
        "coldTempAlert": 500,
        "coldTempAlertEnabled": true,
        "hotTempAlert": 920,
        "hotTempAlertEnabled": true,
        "coolStages": 1,
        "heatStages": 1,
        "maxSetBack": 100,
        "maxSetForward": 80,
        "quickSaveSetBack": 40,
        "quickSaveSetForward": 40,
        "hasHeatPump": false,
        "hasForcedAir": true,
        "hasBoiler": false,
        "hasHumidifier": false,
        "hasErv": false,
        "hasHrv": false,
        "condensationAvoid": false,
        "useCelsius": true,
        "useTimeFormat12": true,
        "locale": "en",
        "humidity": "36",
        "humidifierMode": "off",
        "backlightOnIntensity": 10,
        "backlightSleepIntensity": 4,
        "backlightOffTime": 60,
        "soundTickVolume": 0,
        "soundAlertVolume": 0,
        "compressorProtectionMinTime": 300,
        "compressorProtectionMinTemp": 350,
        "stage1HeatingDifferentialTemp": 5,
        "stage1CoolingDifferentialTemp": 5,
        "stage1HeatingDissipationTime": 31,
        "stage1CoolingDissipationTime": 31,
        "heatPumpReversalOnCool": true,
        "fanControlRequired": true,
        "fanMinOnTime": 0,
        "heatCoolMinDelta": 50,
        "tempCorrection": 0,
        "holdAction": "useEndTime4hour",
        "heatPumpGroundWater": false,
        "hasElectric": false,
        "hasDehumidifier": false,
        "dehumidifierMode": "off",
        "dehumidifierLevel": 60,
        "dehumidifyWithAC": false,
        "dehumidifyOvercoolOffset": 0,
        "autoHeatCoolFeatureEnabled": true,
        "wifiOfflineAlert": false,
        "heatMinTemp": 450,
        "heatMaxTemp": 1200,
        "coolMinTemp": -100,
        "coolMaxTemp": 1200,
        "heatRangeHigh": 752,
        "heatRangeLow": 572,
        "coolRangeHigh": 887,
        "coolRangeLow": 680,
        "userAccessCode": "",
        "userAccessSetting": 0,
        "auxRuntimeAlert": 10800,
        "auxOutdoorTempAlert": 500,
        "auxMaxOutdoorTemp": 700,
        "auxRuntimeAlertNotify": false,
        "auxOutdoorTempAlertNotify": false,
        "auxRuntimeAlertNotifyTechnician": false,
        "auxOutdoorTempAlertNotifyTechnician": false,
        "disablePreHeating": false,
        "disablePreCooling": false,
        "installerCodeRequired": false,
        "drAccept": "always",
        "isRentalProperty": false,
        "useZoneController": false,
        "randomStartDelayCool": 0,
        "randomStartDelayHeat": 0,
        "humidityHighAlert": -1,
        "humidityLowAlert": -1,
        "disableHeatPumpAlerts": false,
        "disableAlertsOnIdt": false,
        "humidityAlertNotify": false,
        "humidityAlertNotifyTechnician": false,
        "tempAlertNotify": true,
        "tempAlertNotifyTechnician": false,
        "monthlyElectricityBillLimit": 0,
        "enableElectricityBillAlert": false,
        "enableProjectedElectricityBillAlert": false,
        "electricityBillingDayOfMonth": 1,
        "electricityBillCycleMonths": 1,
        "electricityBillStartMonth": 1,
        "ventilatorMinOnTimeHome": 20,
        "ventilatorMinOnTimeAway": 0,
        "backlightOffDuringSleep": false,
        "autoAway": true,
        "smartCirculation": false,
        "followMeComfort": true,
        "ventilatorType": "none",
        "isVentilatorTimerOn": false,
        "ventilatorOffDateTime": "",
        "hasUVFilter": true,
        "coolingLockout": false,
        "ventilatorFreeCooling": true,
        "dehumidifyWhenHeating": false,
        "ventilatorDehumidify": true,
        "groupRef": "",
        "groupName": "",
        "groupSetting": 0
      "runtime": {
        "runtimeRev": "170905171929",
        "connected": true,
        "firstConnected": "2017-02-15 17:24:42",
        "connectDateTime": "2017-09-05 05:06:05",
        "disconnectDateTime": "2017-09-05 04:56:58",
        "lastModified": "2017-09-05 17:19:29",
        "lastStatusModified": "2017-09-05 17:19:29",
        "runtimeDate": "2017-09-05",
        "runtimeInterval": 205,
        "actualTemperature": 736,
        "actualHumidity": 42,
        "desiredHeat": 725,
        "desiredCool": 725,
        "desiredHumidity": 36,
        "desiredDehumidity": 60,
        "desiredFanMode": "auto",
        "desiredHeatRange": [
          572,
          752
        "desiredCoolRange": [
          680,
          887
      "extendedRuntime": {
        "lastReadingTimestamp": "2017-09-05 17:05:00",
        "actualTemperature": [
          738,
          737,
          737
        "actualHumidity": [
          43,
          42,
          42
        "desiredHeat": [
          725,
          725,
          725
        "desiredCool": [
          725,
          725,
          725
        "desiredHumidity": [
          0,
          0,
          0
        "desiredDehumidity": [
          0,
          0,
          0
        "dmOffset": [
          0,
          0,
          0
        "hvacMode": [
          "compressorCoolStage1On",
        "heatPump1": [
          0,
          0,
          0
        "heatPump2": [
          0,
          0,
          0
        "auxHeat1": [
          0,
          0,
          0
        "auxHeat2": [
          0,
          0,
          0
        "auxHeat3": [
          0,
          0,
          0
        "cool1": [
          300,
          300,
          300
        "cool2": [
          0,
          0,
          0
        "fan": [
          300,
          300,
          300
        "humidifier": [
          0,
          0,
          0
        "dehumidifier": [
          0,
          0,
          0
        "economizer": [
          0,
          0,
          0
        "ventilator": [
          0,
          0,
          0
        "currentElectricityBill": 0,
        "projectedElectricityBill": 0
      "weather": {
        "timestamp": "2017-09-05 17:04:09",
        "weatherStation": "CW:54391",
        "forecasts": [
            "weatherSymbol": 0,
            "dateTime": "2017-09-05 12:57:08",
            "condition": "Mild.",
            "temperature": 680,
            "pressure": 1006,
            "relativeHumidity": 64,
            "dewpoint": 543,
            "visibility": -5002,
            "windSpeed": 8000,
            "windGust": -5002,
            "windDirection": "",
            "windBearing": -5002,
            "pop": 63,
            "tempHigh": 658,
            "tempLow": 555,
            "sky": -5002
            "weatherSymbol": 1,
            "dateTime": "2017-09-06 12:57:08",
            "condition": "More sun than clouds. Cool.",
            "temperature": 578,
            "pressure": 1009,
            "relativeHumidity": 63,
            "dewpoint": 505,
            "windSpeed": 8000,
            "windGust": -5002,
            "windDirection": "NW",
            "windBearing": 309,
            "pop": 52,
            "tempHigh": 642,
            "tempLow": 514,
            "sky": 8
            "weatherSymbol": 5,
            "dateTime": "2017-09-07 12:57:08",
            "condition": "Showers late. Partly sunny. Cool.",
            "temperature": 568,
            "pressure": 1011,
            "relativeHumidity": 65,
            "dewpoint": 491,
            "windSpeed": 12000,
            "windGust": -5002,
            "windDirection": "W",
            "windBearing": 285,
            "pop": 14,
            "tempHigh": 624,
            "tempLow": 512,
            "sky": 14
            "weatherSymbol": 8,
            "dateTime": "2017-09-08 12:57:08",
            "condition": "Drizzle. Morning clouds. Cool.",
            "temperature": 569,
            "pressure": 1018,
            "relativeHumidity": 60,
            "dewpoint": 470,
            "windSpeed": 11000,
            "windGust": -5002,
            "windBearing": 311,
            "pop": 7,
            "tempHigh": 626,
            "tempLow": 512,
            "sky": 32
            "weatherSymbol": 1,
            "dateTime": "2017-09-09 12:57:08",
            "condition": "Mostly sunny. Cool.",
            "temperature": 554,
            "pressure": 1027,
            "relativeHumidity": 49,
            "dewpoint": 426,
            "windSpeed": 8000,
            "windGust": -5002,
            "windDirection": "NE",
            "windBearing": 46,
            "pop": 44,
            "tempHigh": 633,
            "tempLow": 476,
            "sky": 3
            "weatherSymbol": 1,
            "dateTime": "2017-09-05 12:00:00",
            "temperature": 658,
            "pressure": -5002,
            "relativeHumidity": 66,
            "dewpoint": 539,
            "visibility": 15000,
            "windSpeed": 8000,
            "windGust": -5002,
            "windDirection": "SW",
            "windBearing": 230,
            "pop": 0,
            "tempHigh": -5002,
            "tempLow": -5002,
            "sky": 8
            "weatherSymbol": 5,
            "dateTime": "2017-09-05 18:00:00",
            "condition": "a few showers. Mostly cloudy. Cool.",
            "temperature": 573,
            "pressure": -5002,
            "relativeHumidity": 84,
            "dewpoint": 525,
            "visibility": 10000,
            "windSpeed": 6000,
            "windGust": -5002,
            "windBearing": 295,
            "pop": 56,
            "tempHigh": -5002,
            "tempLow": -5002,
            "sky": 16
            "weatherSymbol": 1,
            "dateTime": "2017-09-06 00:00:00",
            "condition": "Passing clouds. Quite cool.",
            "temperature": 523,
            "pressure": -5002,
            "relativeHumidity": 92,
            "dewpoint": 501,
            "visibility": 9000,
            "windSpeed": 5000,
            "windGust": -5002,
            "windBearing": 315,
            "pop": 10,
            "tempHigh": -5002,
            "tempLow": -5002,
            "sky": 7
            "weatherSymbol": 1,
            "dateTime": "2017-09-06 06:00:00",
            "condition": "More sun than clouds. Quite cool.",
            "temperature": 514,
            "pressure": -5002,
            "relativeHumidity": 100,
            "dewpoint": 521,
            "visibility": 8000,
            "windSpeed": 4000,
            "windGust": -5002,
            "windBearing": 296,
            "pop": 0,
            "tempHigh": -5002,
            "tempLow": -5002,
            "sky": 8
      "events": [
          "type": "vacation",
          "name": "149574607029",
          "running": false,
          "startDate": "2017-11-01",
          "startTime": "17:00:00",
          "endDate": "2017-11-10",
          "endTime": "19:30:00",
          "isOccupied": false,
          "isCoolOff": false,
          "isHeatOff": false,
          "coolHoldTemp": 788,
          "heatHoldTemp": 608,
          "fan": "auto",
          "vent": "off",
          "ventilatorMinOnTime": 5,
          "isOptional": true,
          "isTemperatureRelative": false,
          "coolRelativeTemp": 0,
          "heatRelativeTemp": 0,
          "isTemperatureAbsolute": true,
          "dutyCyclePercentage": 255,
          "fanMinOnTime": 0,
          "occupiedSensorActive": false,
          "unoccupiedSensorActive": false,
          "drRampUpTemp": 0,
          "drRampUpTime": 3600,
          "linkRef": "",
          "holdClimateRef": ""
          "type": "hold",
          "name": "hold",
          "running": true,
          "startDate": "2017-09-05",
          "startTime": "09:59:25",
          "endDate": "2017-09-05",
          "endTime": "13:59:55",
          "isOccupied": true,
          "isCoolOff": false,
          "isHeatOff": false,
          "coolHoldTemp": 725,
          "heatHoldTemp": 725,
          "fan": "auto",
          "vent": "off",
          "isOptional": true,
          "fanMinOnTime": 0,
          "drRampUpTemp": 0,
          "linkRef": "",
          "type": "template",
          "name": "_Default_",
          "running": false,
          "startDate": "2035-01-01",
          "startTime": "00:00:00",
          "endDate": "2035-01-01",
          "endTime": "23:59:59",
          "isCoolOff": false,
          "isHeatOff": false,
          "fan": "auto",
          "vent": "off",
          "isOptional": true,
          "coolRelativeTemp": 40,
          "heatRelativeTemp": 40,
          "isTemperatureAbsolute": false,
          "fanMinOnTime": 0,
          "drRampUpTemp": 0,
          "linkRef": "",
      "program": {
        "schedule": [
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "sleep",
            "sleep",
            "sleep"
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "sleep",
            "sleep",
            "sleep"
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "sleep",
            "sleep",
            "sleep"
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "away",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "sleep",
            "sleep",
            "sleep"
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "sleep",
            "sleep",
            "sleep"
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "sleep",
            "sleep",
            "sleep"
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "sleep",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "home",
            "sleep",
            "sleep",
            "sleep"
        "climates": [
            "name": "Away",
            "climateRef": "away",
            "isOptimized": true,
            "coolFan": "auto",
            "heatFan": "auto",
            "vent": "off",
            "owner": "system",
            "type": "program",
            "colour": 9021815,
            "coolTemp": 752,
            "heatTemp": 644,
            "sensors": [
                "id": "ei:0:1",
                "id": "rs:102:1",
                "name": "Bedroom"
                "id": "rs:100:1",
                "name": "Downstairs"
                "id": "rs:105:1",
                "name": "Kitchen"
                "id": "rs:101:1",
                "name": "Living Room"
                "id": "rs:106:1",
                "name": "Basement"
                "id": "rs:107:1",
                "name": "Lil\u0027bee"
            "name": "Home",
            "climateRef": "home",
            "isOccupied": true,
            "isOptimized": false,
            "coolFan": "auto",
            "heatFan": "auto",
            "vent": "off",
            "owner": "system",
            "type": "program",
            "colour": 13560055,
            "coolTemp": 734,
            "heatTemp": 671,
            "sensors": [
                "id": "ei:0:1",
                "id": "rs:102:1",
                "name": "Bedroom"
                "id": "rs:105:1",
                "name": "Kitchen"
                "id": "rs:101:1",
                "id": "rs:103:1",
                "name": "Office"
                "id": "rs:106:1",
                "name": "Basement"
                "id": "rs:107:1",
            "name": "Sleep",
            "climateRef": "sleep",
            "isOccupied": true,
            "coolFan": "auto",
            "heatFan": "auto",
            "vent": "off",
            "owner": "system",
            "type": "program",
            "colour": 2179683,
            "coolTemp": 743,
            "heatTemp": 662,
            "sensors": [
                "id": "ei:0:1",
                "id": "rs:102:1",
                "name": "Bedroom"
                "id": "rs:105:1",
                "name": "Kitchen"
                "id": "rs:101:1",
                "id": "rs:106:1",
                "name": "Basement"
                "id": "rs:107:1",
        "currentClimateRef": "away"
      "houseDetails": {
        "style": "townhouse",
        "size": 1500,
        "numberOfFloors": 3,
        "numberOfRooms": 3,
        "numberOfOccupants": 0,
        "age": 10,
        "windowEfficiency": 2
      "remoteSensors": [
          "id": "rs:100",
          "name": "Downstairs",
          "type": "ecobee3_remote_sensor",
          "code": "KSWT",
          "inUse": false,
          "capability": [
              "id": "1",
              "type": "temperature",
              "value": "703"
              "id": "2",
              "type": "occupancy",
              "value": "false"
          "id": "rs:101",
          "name": "Living Room",
          "code": "GFHP",
          "inUse": true,
          "capability": [
              "id": "1",
              "value": "749"
              "id": "2",
              "value": "false"
          "id": "rs:102",
          "name": "Bedroom",
          "code": "FZMQ",
          "inUse": true,
          "capability": [
              "id": "1",
              "value": "751"
              "id": "2",
              "value": "false"
          "id": "rs:103",
          "name": "Office",
          "code": "FZMC",
          "inUse": true,
          "capability": [
              "id": "1",
              "value": "740"
              "id": "2",
              "value": "false"
          "id": "rs:104",
          "name": "Garage",
          "code": "F6WT",
          "inUse": false,
          "capability": [
              "id": "1",
              "value": "765"
              "id": "2",
              "value": "false"
          "id": "ei:0",
          "type": "thermostat",
          "inUse": true,
          "capability": [
              "id": "1",
              "value": "725"
              "id": "2",
              "type": "humidity",
              "value": "42"
              "id": "3",
              "value": "false"
          "id": "rs:105",
          "name": "Kitchen",
          "code": "F6YR",
          "inUse": true,
          "capability": [
              "id": "1",
              "value": "734"
              "id": "2",
              "value": "false"
          "id": "rs:106",
          "name": "Basement",
          "code": "G23B",
          "inUse": false,
          "capability": [
              "id": "1",
              "value": "unknown"
              "id": "2",
              "value": "false"
          "id": "rs:107",
          "name": "Lil\u0027bee",
          "code": "JYRB",
          "inUse": true,
          "capability": [
              "id": "1",
              "value": "736"
              "id": "2",
              "value": "false"
  "status": {
    "code": 0,
    "message": ""
} [ecobee1]
2017-09-05 13:21:24 - Ecobee Timer Error - Conversion from string "unknown" to type 'Single' is not valid. [ecobee1
Edited by cswelin
Should be fixed in v0.7.2
Perfect, thank you.
