Many -170001 entries in the error log for one node
Hi io_guy,
I was poking around this morning trying to investigate some issues with responsiveness, and I noticed the error log is filled with 10+ entries per second pertaining to [what appears to be] the alarm node.
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15-5] 10.214.126.206:60150->80
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15]: GET-->/rest/ns/1/nodes/n001_hwalrm
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15-5] 10.214.126.206:60152->80
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15-5] 10.214.126.206:60154->80
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15-5] 10.214.126.206:60156->80
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15-5] 10.214.126.206:60158->80
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15-5] 10.214.126.206:60160->80
Wed 2017/09/06 05:59:57 AM	System	-170001	[HTTP:0-15-5] 10.214.126.206:60162->80
If I manually hit that /rest URL above, I get a 404:
<RestResponse succeeded="false">
<status>404</status>
<reason code="2003"/>
</RestResponse>
I'm guessing this isn't normal behavior, and I don't see it for any of the other nodes I'm using on Nodelink... Everything is still functioning as expected, I'm just wondering about all that activity and if it's possibly related to some intermittent sluggishness I've been experiencing, especially with alarm events.
Thanks!  Oh - and also thanks for the update for entry delay on stay, again much appreciated!
I can only work with NodeLink logs. Enable verbose on the main page and see if it coincides with those.
Looking at both, it seems to roughly correspond with /report/status events below that are cycling every few seconds, which seem to perhaps fire off after each heartbeat change? I think this is enough of a snippet to show what's going on as it seems to be somewhat repetitive, but let me know if you need a longer excerpt.  Thanks!!!
2017-09-06 11:00:21 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 1)
2017-09-06 11:00:21 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 2)
2017-09-06 11:00:21 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 3)
2017-09-06 11:00:21 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 4)
2017-09-06 11:00:21 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 5)
2017-09-06 11:00:21 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-09-06 11:00:21 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 5)
2017-09-06 11:00:21 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 6)
2017-09-06 11:00:21 - ISY: Variable hwalrm1-ST added to queue (Val: -1, QS: 7)
2017-09-06 11:00:21 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-09-06 11:00:21 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-09-06 11:00:21 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-09-06 11:00:21 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-09-06 11:00:22 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-09-06 11:00:22 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-09-06 11:00:22 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-09-06 11:00:23 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 1)
2017-09-06 11:00:23 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 1, QS: 2)
2017-09-06 11:00:23 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 3)
2017-09-06 11:00:23 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 4)
2017-09-06 11:00:23 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 5)
2017-09-06 11:00:23 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 0, QS: 6)
2017-09-06 11:00:23 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-09-06 11:00:23 - ISY: Variable hwalrm1_part1-GV3 added to queue (Val: 0, QS: 6)
2017-09-06 11:00:23 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 7)
2017-09-06 11:00:23 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/1/25)
2017-09-06 11:00:24 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-09-06 11:00:24 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-09-06 11:00:24 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-09-06 11:00:24 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/0/25)
2017-09-06 11:00:24 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV3/0/25)
2017-09-06 11:00:24 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 2)
2017-09-06 11:00:24 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 3)
2017-09-06 11:00:24 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 4)
2017-09-06 11:00:24 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 5)
2017-09-06 11:00:24 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/1/25)
2017-09-06 11:00:24 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 5)
2017-09-06 11:00:24 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 6)
2017-09-06 11:00:24 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 7)
2017-09-06 11:00:24 - ISY: Variable hwalrm1-ST added to queue (Val: -1, QS:
2017-09-06 11:00:24 - ISY: Variable caiwc1-ST added to queue (Val: 1, QS: 9)
2017-09-06 11:00:24 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-09-06 11:00:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-09-06 11:00:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-09-06 11:00:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-09-06 11:00:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-09-06 11:00:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-09-06 11:00:25 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-09-06 11:00:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-09-06 11:00:26 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_caiwc1/report/status/ST/1/25)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_z06-ST added to queue (Val: 1, QS: 1)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 2)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 3)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 4)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 5)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 6)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 0, QS: 7)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part1-GV3 added to queue (Val: 0, QS:
2017-09-06 11:00:28 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS: 9)
2017-09-06 11:00:28 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_z06/report/status/ST/1/25)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 9)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS: 10)
2017-09-06 11:00:28 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 10)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 11)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 12)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 13)
2017-09-06 11:00:28 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 14)
2017-09-06 11:00:28 - ISY: Variable hwalrm1-ST replaced in queue (Val: -1, QS: 14)
2017-09-06 11:00:28 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/0/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV3/0/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-09-06 11:00:29 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-09-06 11:00:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-09-06 11:00:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-09-06 11:00:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-09-06 11:00:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-09-06 11:00:30 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_z21-ST added to queue (Val: 1, QS: 1)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part1-GV6 added to queue (Val: 0, QS: 2)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part1-GV2 added to queue (Val: 0, QS: 3)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part1-GV5 added to queue (Val: 0, QS: 4)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part1-GV4 added to queue (Val: 0, QS: 5)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part1-GV1 added to queue (Val: 0, QS: 6)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part1-ST added to queue (Val: 0, QS: 7)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part1-GV3 added to queue (Val: 0, QS:
2017-09-06 11:00:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_z21/report/status/ST/1/25)
2017-09-06 11:00:32 - ISY: Variable hwalrm1-ST added to queue (Val: 1, QS:
2017-09-06 11:00:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV6/0/25)
2017-09-06 11:00:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV2/0/25)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part2-GV6 added to queue (Val: 0, QS: 7)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part2-GV2 added to queue (Val: 0, QS:
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part2-GV5 added to queue (Val: 0, QS: 9)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part2-GV4 added to queue (Val: 0, QS: 10)
2017-09-06 11:00:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV5/0/25)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part2-GV1 added to queue (Val: 0, QS: 10)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part2-ST added to queue (Val: 0, QS: 11)
2017-09-06 11:00:32 - ISY: Variable hwalrm1_part2-GV3 added to queue (Val: 0, QS: 12)
2017-09-06 11:00:32 - ISY: Variable hwalrm1-ST replaced in queue (Val: -1, QS: 12)
2017-09-06 11:00:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV4/0/25)
2017-09-06 11:00:32 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV1/0/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/ST/0/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part1/report/status/GV3/0/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1/report/status/ST/-1/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV6/0/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV2/0/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV5/0/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV4/0/25)
2017-09-06 11:00:33 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV1/0/25)
2017-09-06 11:00:34 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/ST/0/25)
2017-09-06 11:00:34 - ISY: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_hwalrm1_part2/report/status/GV3/0/25)
Nothing wrong there.  You'll have to see what UDI says on their side.
I checked my log, very few 170001s.  Any chance you have HTTP KeepAlive disabled under NodeLink system config?
