ISY Portal Maintenance - 09-10-2017
Hello everyone,
We will have a maintenance this Sunday 09-10-2017 at 5:00 AM PDT which will last 1 hour. During this period, the subscriptions through ISY Portal are expected to be interrupted for a few minutes.
Changes
Separation of Amazon Echo / Google Home user interfaces.
- New code in preparation for Amazon Echo Smart Home V3
Yes, you read correctly! A new version of the Amazon Echo Smart Home skill is coming out in the next few weeks. Stay tuned.
The main change for this update which will be visible is that Amazon Echo and Google Home UI will be separated. Both devices share many identical features, but each also have their own particularities, so we felt that a separate configuration page with only the relevant features would be best in the long run. In particular, on the Amazon Echo page, you will see a new "Live Update" button. This is a feature that will be relevant only with the new Smart Home Skill V3.
The Google Home spokens and Amazon Echo spokens will be the same initially. If you use only an Amazon echo, feel free to delete the Google Home spokens. The same goes if you are using only Google Home.
Benoit
