Button pressed / released (more than 500 ms) events
Apparently Insteon will send a command when a paddle button is pressed more than 500 ms - a button pressed and released event. Will the next release of ISY support triggering an event off this?
What I want to do is find a way to have a switch normally operate a single light in a room, but if I do something different (double click, hold it a bit longer, etc) have it trigger an event that will turn all the lights in the room on or off.
Any suggestions?
Yes, you can do that in the next release (currently in beta).
A button press can send either an On/Off/Fast On/Fast Off/Brighten/Dim.
Using the new triggers (now called 'programs'), you can have a switch operate a single light using on/off, but have it operate a whole room using Fast On/Fast Off.
You can have it do it only at certain times, or even have it operate differently at different times.
Great! Perfect!
I'm ready to try the beta - has it yet been tested with the java SDK?
By the way - can you somehow determine if a button has been double clicked (fast on / fast off) with the current release of the JDK?
