Integrating ISY/MobiLinc with Amazon Echo
I recently purchased an Amazon Echo, and I would like to integrate it with my ISY. From what I understand, I cannot use the ISY Portal if I already have the MobiLinc Connect Portal. Does that mean that any integration has to be done using MobiLinc? Can anyone point me in the right direction for the best way to integrate? I tried adding the MobiLinc and MobiLinc Smart Home skills, but it's not detecting my devices. I'm not sure what I'm doing wrong. I don't mind if I have to purchase anything. I just want to be able to get this working. I appreciate any suggestions or advice.
That's true. You can use the ISY portal with MobiLinc, but not with the MobiLinc portal or you can use the MobiLinc portal without the ISY portal. That is, only one portal at a time. Wes is really helpful, have you asked at the MobiLinc forum?
Good suggestion, thanks! I will post over there.
Duplicate posts may result in conflicting responses. Delete the other before someone responds.
