James Peterson Posted October 17, 2017 Share Posted October 17, 2017 In the next beta release I will be re-releasing "run in background". It is going to utilize the optimizations settings in your device. It will require the user to manually set Agave into "Do not optimize" mode. If you don't want to use this mode you don't have to and run in background will not appear in your settings. I will also add a quick link within settings to take you to your devices optimization settings. Hopefully this will allow Agave to work better in your pocket or simply maintain connection when the screen is off if you want to run it that way. If this works, I will see about live notifications or more. Link to comment
