Voice under notes in admin console
mrobles
How do I start the console so I get the voice box under notes? I tried from myisy and from the icon on my desktop and don't see that option under notes.
What am I doing wrong?
Obviously this is needed so alexa knows what your device is.
Thanks for the quick reply.
I don't think that helps me. I am using mobilinc and not the portal. I am talking about the voice section that is missing in note as below. I have been able to access in the past.
You should post in the Mobilink section to get the help of the author.
I don't think its a mobilinc issue. Here are their instructions.
1. Use the ISY's Admin Console and right-click on your device or scene and select "Notes".
2. Under the "Spoken" field enter in simple English to describe your device/scene. For example: "Upstairs Office".
My problem is with the ISY console.  I have done it in the past but cant access now. I am talking about right clicking a device then go to the note and access the spoken field. This has nothing to do with Mobilinc, its the console that is not showing the field.
Thanks again for your help
The images you posted are a carry-over from earlier versions. They have no purpose other than notations. The "spoken" field has no other purpose. It's not used for anything.
It's used by MobiLinc. That's its whole purpose for being.
Edited by Gary Funk
  On 10/23/2017 at 1:13 AM, mrobles said:
My firmware is 4.6.2 and UI is 4.1.2
How do I upgrade the UI? I did google but could not find a solution.
Thanks in advance.
Mike
Go to the post for 4.6.2 and download the UI.
Sent from my SM-G955U1 using Tapatalk
  On 10/23/2017 at 1:59 AM, mrobles said:
Thanks for all the help. I just got 4.6.2 and the spoken field is there.
Remember, you have to update the Admin Console when you update the ISY.
  On 10/23/2017 at 3:53 AM, Scottmichaelj said:
What does Mobilinc use spoken fields for?
MobiLinc has had voice control long before the Echo was a product.
My understanding is you put in the spoken word you want to use for that device and then when you say the word MobiLinc knows which device you want.
