Using IR to select a Switch.
Hi. I was wondering if it would be possible to select a insteon Switch and using the volume to adjust the brightness of the lamp, like X10 control, by programming it with the console??
Exemple
Press 1 on the Harmony to select Switch 1
Now the volume control the switch 1 level.
Press 3 on the Harmony select switch 3
and now the volume control the switch 3 level.
Thank you
