ZWave devices missing in portal
While reconfiguring some devices and playing around with the Alexa groups and routines, I noticed that 2 of my 3 ZWave devices are missing from the available devices dropdown list on the portal.
They appear on the admin console and function properly. I need to add them back to Alexa and can't now.
Am I missing a way to refresh the list?
Sent from my HTC U11 using Tapatalk
The first device is a scene switch (dimming wall wart module) with address ZW002_1.  The second is a thermostat with address ZW004_1.
The thermostat had spokens for it at one time, but now it's completely gone.
Edited by Brad
Have you tried Synchronize?
If that's the button with the double circular store that says Refresh when you hover over it, then yes. If there's another button/link, then I'm not seeing it.
Z-Wave, Tools, Synchronize Nodes
Tried that.  Event viewer showed success.  Still missing from the portal device dropdown list.  This is strange.
The 3rd ZWave device I have that shows up in the list is a Go Control security panel.  It's device address is ZW003_1.  I'm wondering if this is an edge case bug where the first and last ZWave devices are overlooked.
Edited by Brad
Well, am I  :oops: . I gave advice before thoroughly checking. You are correct. Z-Wave devices do not show up in the portal. A scene or program may be the solution.
Oh wow!  You rock Benoit!  Thank you very much.
I deleted my previous post with additional details since you beat me to the Post button.
I've been lurking for several years and am really impressed with the customer service and quick response.  I'm a happy camper now.
Once again a quick fix. Million merci B)
I need some help......  Before I read that others had the same problem with Devices I tried several solutions and ended up deleting all existing Devices from the Google Home connectivity. I also deleted  Universal Devices from the Google Home App.
When the Devices were showing again, I added a few of my Zwave devices again to the Portal Google Home connectivity and added Universal Devices again to the Google Home App.The new devices show in the Google Home App but when I ask Google Home to turn the specific light ON (with the chosen spoken word) I get error message that it can not control my device. However I do not have a problem with my Alexa setup.
What can I do to make the Google Home work ?
Hi Seno,
What device did you try to turn on that did not respond? I see that you have only 3 devices for GH, and a lot more for Alexa.
I see the device discovery for GH Worked, and I don't see any failed requests for any device actions
Benoit
Hi Benoit... Bonsoir !
I only added 3 devices in GH because I wanted to try these first. These show in the GH App but I get systematically an error message "I do not know how to help with that" when I ask GH to turn on one of these devices.  It used to work before.
I rebooted my two GH's, I rebooted the ISY.....
I will add more devices tomorrow and see if I have any luck with other devices. I will also try with a Scene.
I will keep you informed.
Hi Seno,
Benoit
Hi Benoit
For everyone's benefit, I finally sorted it out with Google Home support (U.S.: 1-855-971-9121) when I realized that the problem was not just with ISY but also with my Nest thermostats.
We did a factory reset on my Google Home (press button at back of Google Home till lights go full orange), and then follow the steps in the Google Home App to set up the Google Home device.
After that, both Nest thermostats and my ISY devices work again with Google Home.
If you have more than one Google Home device,  before doing the factory reset on the first Google Home, make sure to disconnect power from your other Google Home device(s).  When first Google Home factory reset is complete, then power the other and perform same factory reset.
Edited by asbril
