G W Posted November 21, 2017 Share Posted November 21, 2017 Amazon has just released the V3 Skill. Quote Link to comment
roblombardo Posted November 21, 2017 Share Posted November 21, 2017 Just installed it! Quote Link to comment
bipto Posted November 21, 2017 Share Posted November 21, 2017 What's new / different in V3..? Quote Link to comment
Teken Posted November 21, 2017 Share Posted November 21, 2017 What's new / different in V3..? https://forum.universal-devices.com/topic/22604-what-is-live-update-and-smart-home-skill-v3/?p=221267 Quote Link to comment
stusviews Posted November 21, 2017 Share Posted November 21, 2017 A few concerns (not in any way to be construed as complaints): All devices show as offline. (Schlage) deadbolts appear twice. Dimmable Insteon devices appear twice, one as the original entry and the others as an entry labelled, "ISY Dimmable device" followed by the Insteon ID. 1 Quote Link to comment
Rob Posted November 21, 2017 Share Posted November 21, 2017 (edited) A few concerns (not in any way to be construed as complaints): All devices show as offline. (Schlage) deadbolts appear twice. Dimmable Insteon devices appear twice, one as the original entry and the others as an entry labelled, "ISY Dimmable device" followed by the Insteon ID. EDIT: I see the behavior stusviews describes on the alexa web portal but not the ios app. I've pretty much stopped using the web portal as it has yet to be updated for routines and smart groups, unless I'm missing something. Did you disable the V2 skill? I'm not seeing that behavior. On a side note, it appears as though the smart groups feature works as intended, although only with devices and not scenes. I can now say "turn off the lights" in the office and the lights turn off. Edited November 22, 2017 by Rob Quote Link to comment
G W Posted November 21, 2017 Author Share Posted November 21, 2017 A few concerns (not in any way to be construed as complaints): All devices show as offline. (Schlage) deadbolts appear twice. Dimmable Insteon devices appear twice, one as the original entry and the others as an entry labelled, "ISY Dimmable device" followed by the Insteon ID. I did have any of those issues. I suggest you remove and discover. Sent from my SM-G955U1 using Tapatalk Quote Link to comment
MWareman Posted November 21, 2017 Share Posted November 21, 2017 I also disabled v2 before linking v3. No issues like those described... so far.. Quote Link to comment
Paulk8 Posted November 22, 2017 Share Posted November 22, 2017 I also see the original devices. How can I delete all the devices and rediscover? Quote Link to comment
bmercier Posted November 22, 2017 Share Posted November 22, 2017 What's new / different in V3..? Here's the updated changes: https://forum.universal-devices.com/topic/22951-v3-skill-new-features/ Benoit Quote Link to comment
stusviews Posted November 22, 2017 Share Posted November 22, 2017 Forget All followed by Discover works. Devices, scenes and programs no longer show as off-line. This procedure also forgets and re-discovers devices, scene and programs. Groups need to be re-created. A major change, for the good IMO, is that Insteon devices are in the Devices panel and Insteon scenes are in the scene panel. With v2. both devices and scenes were considered devices. 1 Quote Link to comment
Teken Posted November 22, 2017 Share Posted November 22, 2017 Forget All followed by Discover works. Devices, scenes and programs no longer show as off-line. This procedure also forgets and re-discovers devices, scene and programs. Groups need to be re-created. A major change, for the good IMO, is that Insteon devices are in the Devices panel and Insteon scenes are in the scene panel. With v2. both devices and scenes were considered devices. Nice ~ Thanks for that insight. Quote Link to comment
Paulk8 Posted November 22, 2017 Share Posted November 22, 2017 Where is this forget all button??? Thanks Quote Link to comment
TheFallenAngel Posted November 22, 2017 Share Posted November 22, 2017 Where is this forget all button??? Thanks Only available on the website, not in the phone apps - at the bottom of the device list. Sent from my SM-G935W8 using Tapatalk Quote Link to comment
roblombardo Posted November 22, 2017 Share Posted November 22, 2017 (edited) I have upgraded to V3. As I begin to rebuild routine actions, I'm finding that programs are now listed under "scenes" and there is no "scene off" action? I was using routines to call then or else portions of programs where then was on and else was off. Verbal commands to Echo seem to work fine, It's just routines where off is not available. Any suggestions? This is a significant problem, because routines were the only way to address the garage open close issue. I suppose, a separate program could be written for each on or off routine, but that just seems ridiculous. Edited November 22, 2017 by roblombardo Quote Link to comment
stusviews Posted November 23, 2017 Share Posted November 23, 2017 Ditto. None of my routines that run programs which depended on both On and Off are working. Just when I thought the Open/Close difficulty had been solved. Quote Link to comment
bmercier Posted November 23, 2017 Share Posted November 23, 2017 Ditto. None of my routines that run programs which depended on both On and Off are working. Just when I thought the Open/Close difficulty had been solved. This has just been submitted to Amazon. ISY Programs are exposed using the "Alexa.PowerController", under the scenes category; This means that the On and Off should be available to routines IMHO. Benoit Quote Link to comment
stusviews Posted November 23, 2017 Share Posted November 23, 2017 Info only: Reverted to v2 for the sake of WAF. Had to recreate routine actions. The routines themselves remained. 1 Quote Link to comment
TheFallenAngel Posted November 23, 2017 Share Posted November 23, 2017 (edited) Routines don't show the scenes now.. So can't be included, that forces me to go back to V2 {sadly} First image shows some of my scenes listed, rhw other two screens show that when adding to routines they don't show under scenes nor devices. Sent from my S7 Edge using Tapatalk Edited November 23, 2017 by TheFallenAngel Quote Link to comment
G W Posted November 23, 2017 Author Share Posted November 23, 2017 (edited) All this "Artificial Intelligence" is great. Maybe in 10 years. Sent from my SM-G955U1 using Tapatalk Edited November 23, 2017 by Gary Funk Quote Link to comment
stusviews Posted November 23, 2017 Share Posted November 23, 2017 Artificial Intelligence is fine. The problem is human intelligence or, rather, lack of same Quote Link to comment
G W Posted November 23, 2017 Author Share Posted November 23, 2017 My definition of fine is not as liberal as yours. Sent from my SM-G955U1 using Tapatalk Quote Link to comment
stusviews Posted November 23, 2017 Share Posted November 23, 2017 Liberally, that's just fine Quote Link to comment
Goose66 Posted November 24, 2017 Share Posted November 24, 2017 Are we doing this again? Quote Link to comment
