Help with a switchlinc problem.
Need help with a switchlinc dimmer.
This dimmer is a part of a scene that it shouldn't be part of. It doesn't display in the ISY UI. I noticed that when I activated my motion sensor on the back patio, these lights would come on in the house. Every time I activate the scene, these lights come on. The ramp for this switch is about 0.1sec whereas the rest of the scene is set for 19sec.
I factory reset the switch last night and the problem went away, but when I try to restore the switch from the ISY after the factory reset, the problem returns.
I also tried deleting the switch from the ISY and readding it to see if the ISY would pick up on it being a part of the scene when I readded it and nothing. It only shows it being managed by one dummy switch and not a part of any other scenes.
Any suggestions as to how I go about fixing this issue in both the ISY and the switchlink?
ryarber, please try adding the switch to the scene it thinks it belongs to and then removing it from said scene.
Rand
