Insteon 2663-222 dual outlet only controls one outlet from admin.jnlp
macOS High Sierra, ISY994 Administrative Console v4.6.2
I linked the Insteon 2663-222 by pressing each of the top and bottom set buttons separately, and the Administrative Console shows them as separate devices (even named them -Top and -Bot automatically), but only one outlet is controlled. Clicking [Fast On] on either device button in the Admin Console UI only controls the top outlet.
Now here's the really weird part: they work correctly (e.g. independently) when I use the web portal https://my.isy.io/udajax/udajax.htm?mode=corp#/nodes/devices/ so I know it's possible for them to be controlled separately.
I really want my programs to be able to control the outlets separately; any ideas how to fix this
Edited by VoiceOfSoftware
Are both your firmware and UI the same?
You should not need to add the outlet top and bottom separately as it's one device (same Insteon ID) with two modes, just as a KPL is one device with several modes. Try deleting the outlet and re-adding it, just once. Any success?
BTW, I'm using 4.6.2 also,
No difference. It creates 46.E9.E4.1 On-Off Top and 46.E9.E4.2 On-Off Bot, but only one outlet is controlled.
Do you have anything plugged into each outlet? Just probing, I don't know why you're getting those results. I can control each outlet separately with the same ISY version. Have you tried On/Off rather than Fast On?
That's it! [Fast On]/[Fast Off] can only control the one outlet.
[On]/[Off] works for each independently. Thanks very much for your fast and helpful troubleshooting!
