Honeywell TCC on Raspberry Pi
I am attempting migrate from a Windows machine to running Nodelink under Mono on a Pi.  Every node I have set up works fine except for the Honeywell TCC device.  It times out when trying to log in and increasing the timeout length does not help.  The same configuration works fine under Windows.
TCC Login Error: The request timed out [hwstat1]
Is there a limitation that is causing this?
