Ecobee: Weather no longer available in programs
Before I post this in the 5.0.11 thread wanted to check in here...  I noticed a program I have that relies on Ecobee's outside temp via the weather node was no longer working.  In looking at it, I see that when I highlight that line it just displays the first device in my device tree - and scrolling through available devices the weather node is no longer available to use with 'status'.  I know you did some work on weather recently, so just wanted to make sure it wasn't anything you did before bringing it up as a bug.
Yep, same problem here.  I'll look into it, likely something I did when I added forecasts.
Looks like this is an ISY bug, will patch on my side until the next V5 release.
