Z wave with current sense?
Are there any z wave lamp modules that have "current sense" like some versions of the insteon lamp modules? I want to be able to turn on lamps with the switch, as well as having the automation capability.
Sent from my SM-G920V using Tapatalk
You may also want to look at the switches specification information.
The feature you are looking for is also called"Local Control" by some manufacturers.
I have a couple of zwave modules. It was my hope that low-power lighting would not glow dimly when off, but I was disappointed. I assume that this is an indicator that there is some form of current sense built in, likely for the reason you ask.
