March 25, 200917 yr I am adding a third #2443 access point in my home and want to be sure I add it properly. Before plugging in the third access point which one of the two previously installed access points do I put into setup mode(pressing button 4 times) Do I use the very first one i installed? or the second one I installed? The manual was not very clear on this!
March 25, 200917 yr To add a third AccessPoint, simply plug it in at the location you desire. The steps outlined in the manualy are only to ensure that the first two AccessPoints are on different phases. Once they are, it doesn't matter where additional AccessPoints are plugged in - simply locate them where you need them. No linking required.
