ISY 994i adding z-wave?
Hello, I primary use all insteon devices and run an ISY 994i. Can I add Z-Wave support to this device? If so, how? Silly questions, but not sure. I am looking to buy an August lock which requires z-wave.
Yes, you certainly can add a Z-Wave module to the ISY 994i. I did primarily for the same reason, to add Z-Wave locks. I chose Schlage as I was replacing existing non-automated Schlage locks and kept the same keys. I also liked the style.
Do you simply buy the module? No physical hardware to make the device find the z-wave devices? I believe with insteon I had a module that plugged into the wall or something.
Does the schlage lock work with a phone to lock/unlock doors? From what I read, it seems it's all pin driven?
One does not simply add only the zwave add on though - especially for locks.
As many of us found out - zwave requires at least 3 powered (non battery) devices to form an initial mesh. Locks don’t count, but the ISY does.
Most locks need a security enabled beam forming repeater device - like the Aeon Siren (although other devices are now reported to be as good). Avoid the original Aeon ‘repeater’ - it does not work with locks.
