Removing Non-Existing Devices from ISY
So, I borrowed a whole bunch of devices from a friend and added them to my ISY to do some testing over the weekend. Of course I had to remove the borrowed devices, but I did so before I removed them from my ISY.
Now I cannot remove the devices from the ISY. Each time the request fails. I was able to remove a few scenes that came with these devices, but not all..
What do I do?
What do I do?
Burak, are you right clicking the device and selecting Remove? Not from a scene, but from My Lighting? There should not be any failures then as the ISY should ignore the device itself and just delete any other links from/to it.
Rand
What do I do?
Rand
That is what I thought should happen but the request fails. The event log is:
2009/04/06 17:37:03 : [FESK SWLD 2] Start : Removing from scene 'Scene 85'
2009/04/06 17:37:03 : [FESK SWLD 2] Removing PLM group 44 as Controller
2009/04/06 17:37:03 : [MNG-LNK-RSP ] 02 6F 80 E2 2C 0E F4 84 01 01 35 15
2009/04/06 17:37:03 : [FESK SWLD 2] Using engine version i1
2009/04/06 17:37:03 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:37:12 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:37:21 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:37:25 : [FESK SWLD 2] Removing 'FESK KPLA' as Controller
2009/04/06 17:37:25 : [FESK KPLA] Using engine version i1
2009/04/06 17:37:25 : [iNST-ACK    ] 02 62 0E.29.F6 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:37:34 : [iNST-ACK    ] 02 62 0E.29.F6 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:37:43 : [iNST-ACK    ] 02 62 0E.29.F6 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:37:47 : [FESK SWLD 2] Using engine version i1
2009/04/06 17:37:47 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:37:56 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:38:05 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:38:09 : [FESK SWLD 2] Finish : Removing from scene 'Scene 85' was Incomplete
2009/04/06 17:38:09 : [FESK SWLD 2] Using engine version i1
2009/04/06 17:38:09 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:38:18 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:38:27 : [iNST-ACK    ] 02 62 0E.F4.84 0F 28 0F 06          SET-MSB(0F)
2009/04/06 17:38:31 : [FESK SWLD 2] Start : Removing device from ISY
2009/04/06 17:38:31 : [FESK SWLD 2] Finish : Removing from ISY was Incomplete
ok reverting to i1 only instead of Auto solved the problem.
Oh, that is not good. v2.7.2?
Rand
Rand
Yes.
