NodeLink forgets ISY Password
On 7/2/2018 at 10:44 AM, io_guy said:
That's not a full log, you're just copying from the log window so it's truncated.  Log to file.
I'm not copying anything.  Im attaching the file directly from the node folder
Than grab a day earlier too cause that file doesn't include the startup or any info leading up to the errors.
I have sent you every log file I have in a zip.  the log for 07-11 should have a startup, then the error and a restart then the error.
You don't have the node server setup on the ISY:
ISY: <?xml version="1.0" encoding="UTF-8"?><connections all="true"></connections> (profiles/ns/0/connection)
