Mini Remote - Address Illegible
The address sticker on my 2342-2 mini remote has worn off to the point of illegibility. Am I out of luck?
I suppose I can assume 44 8C and try all 256 remaining combinations. Hoping there is a better way.
Manually link it to another Insteon device you can than see the linked address association.
Well it is kind of a roundabout way.
Manually link it to a module in the Administrative Console or add a new module to the console then manually link the remote to it.
Then in the Tools menu. Do a  show a device link table and then a compare to what the ISY994i knows about. The remotes six digit ID should be pointed out as an extra link or link mismatch.
Then you have to remove the remote from the module and factory reset it. Maybe a restore device from the ISY994i would take care of the module itself.
