June 23, 20188 yr I found some older forums links that indicated (and I thought I had seen it on the sales page) where you could purchase a hardware antenna for either z-wave or zigbee for the isy994i. However, when I checked the sales site, I only see the zigbee one. Looks like you have to buy the new unit now if you want Z-wave? (it's listed as an "upgrade" but it appears it's an entirely full/new unit?) Is that the case? Thanks!
June 23, 20188 yr 24 minutes ago, hurnik said: I found some older forums links that indicated (and I thought I had seen it on the sales page) where you could purchase a hardware antenna for either z-wave or zigbee for the isy994i. However, when I checked the sales site, I only see the zigbee one. Looks like you have to buy the new unit now if you want Z-wave? (it's listed as an "upgrade" but it appears it's an entirely full/new unit?) Is that the case? Thanks! https://www.orchestratedhome.com/shop/pc/Z-wave-Radio-Add-on-Board-for-ISY-994i-32p368.htm
June 24, 20188 yr 1 hour ago, gzahar said: https://www.orchestratedhome.com/shop/pc/Z-wave-Radio-Add-on-Board-for-ISY-994i-32p368.htm The external antenna for the Z-wave board was discontinued as it didn't increase the signal strength. You best bet is to install a z-wave repeater close to the ISY. Aeotec has several options available which repeat the z-wave signals.
June 24, 20187 yr Author 16 hours ago, gzahar said: https://www.orchestratedhome.com/shop/pc/Z-wave-Radio-Add-on-Board-for-ISY-994i-32p368.htm Thanks, that's what I was looking for. I couldn't find it on the Universal Devices sales page.
