Elk Outputs Not Showing Correctly
apostolakisl
7 hours ago, apostolakisl said:
This is happening to more and more output labels.  The correct label is Lt Side Beds, I have no idea what the "dro,t" means.
It looks like you haver edited the name.  Tap on it and see if there is a custom name applied to that output.  It should work the same as any other device that has a custom name.
Link to comment
OK, I see that this is the case.  I was able to delete the name and it went back to correct.  Except I never did this.  I suppose it could have "butt dialed" itself in there.   But something is up with this, I had 5 outputs like that.
Also, I find it very frustrating that when I open Elk, it shows the status of my Elk, but it is wrong.  Upon opening it shows a status of things that I suppose is saved from the last time I had Agave open.  It takes a good 10 to 20 seconds before it updates to the current status from ISY.  But it appears as though it is showing you the current status while you wait.  When you open Agave, it should not show you an old status, it should show you the current status or nothing at all.
Link to comment
I'll see what I can do about that.
Link to comment
