Cannot add new Insteon Siren. getting error Unsupported device:7.30
Model 2868-222
Revision 4.1 2117
IMG_3836.HEIC
Is there any new information that can be shared about the 2868-222 Siren V.46?
When I added it to V5.16B, it shows 6 different nodes (see below picture). Only the first node has any information on it. If you press the side button on the Siren, it will change from a chime (green light) to a siren (green light) to off (red light).
Also, if you add the first node to a scene, within the scene you can change the response to be either siren or chime, and the length of time duration, as well
