Z-Wave 0-10 Volt Dimming Ballasts
Hi there,
I've noticed that more and more recessed can lighting products are going towards all in one LED fixtures that can be controlled with a low voltage dimmer or 0-10 volt ballast system.
Insteon no longer makes their 0-10 volt in line ballast product. Fortunately, the ISY supports Z-Wave. There are a couple of 0-10 volt ballasts controlled by Z-Wave available, including the Cubino.
Has anyone tried a scene setup using an Insteon dimmer as the controller and one of these Z-Wave 0-10 volt ballasts as the responder? Does it work, and if it does, does it work well? If it does, this might be the answer the the problem with light flickering controlling dimmable LED lights with existing Insteon dimmers.
