ISY 99 pro turning lights on automatically! argggggh
My ISY worked fine for about a year, then a few months ago started turning lights on randomly. Sometimes it would occur soon after turning off a light manually (turn itself back on several minutes later), sometimes completely random, wake up and have 3 lights on.
I unplugged it for a few months, then recently had time to try to trouble shoot, i updated its software, and it seems to be a *little* better, but still getting random on's and still get it turning lights back on soon after i turn them on.
There is also an ELK involved, but that seems to be functioning fine.
Anybody seen this (and i do not believe it is any of the insteon devices as they all work properly when the ISY is unplugged).
Yes, I had some of those problems. I had to factory reset the devices that were "magically" turning on to make the problem go away. It was the only way I found to fix it.
This is a known issue with older Elk firmware. Do you know which firmware you are running on your Elk?
Please see this thread:
http://forum.universal-devices.com/view ... sc&start=0
was running 5.1.8....just went to 5.1.14, should do the trick per the other thread, thanks!
