passing a node # to another program?
Hi all,
I'm still new here and very much enjoying my time learning how to use my new isy994i.
I'm trying to write a program that will alert me if the back door is open, and continue to alert me every 5 minutes until it's closed.
Here's the Door Open Alert:
Quote
Door Open Alert - [ID 001F][Parent 0024]
        Status  'Home / Sensors / Back Door / Back Door' is On
     Or Status  'Home / Sensors / Freezer Door / Freezer Door' is On
        Send Notification to 'Me' content 'Door Alert Open'
        $Back_Door_Open  = 1
        Run Program 'Repeat Door Open Notification' (If)
Comment
the program that gets called (Repeat Door Open Notification (If)) is like this:
Quote
Repeat Door Open Notification - [ID 0025][Parent 0024]
        $Back_Door_Open is 1
        Repeat Every  5 minutes
But when the second program runs, the email alert can't decode (?) / interpret (?) the variable.
Quote
Email Template:
${sys.node.#.name} is open
Date: ${sys.date}
Time: ${sys.time12}
Extra Info:
ST: ${sys.node.#.ST}
Raw: ${sys.node.#.ST.raw}
the sys.node.#.name just comes in as "node[#]".
so, all this to say... is there a way to catch the node # into a variable so I can use it elsewhere?
Tips welcome!
Tips welcome!
I don’t believe so. But it’s a GREAT idea! I suspect the ISY would need to support string variables though - and it does not have the ram for that.
The "${sys.node.#.name} is open" only references the program that called it. In this case "Email Template"
Create a new custom email that specifically references the node, i.e. BACK DOOR OPEN., then call that custom email rather than the node.
I can do that.  I was hoping to be able to use a single email template for all the alerts (adding a new sensor would just be a matter of adding it to the If clause), but it seems ISY doesn't work that way -- which is fine, just not what i was hoping for.
Your other option is to place all your code into one program. When the IF statement is FALSE the ELSE statement will run.
     Repeat 50 times
    Send Notification to 'Me' content 'Email templete'
     Wait 5 minutes
If I'm understanding the request correctly, I use a single email template for alarm violations and have a separate program for each with a descriptive name.  My email template contains "${sys.program.#.name}", and I call it from programs named something like "Dining Room Door Violated".  I have one of these programs for each zone that I want to monitor independently.
You only need one program for your freezer and back door.  See the attached image to set up your email. The email you receive will show the node that triggered it as well as the node status and  date and time it was triggered.
The <br> is a carriage return
Edited by Techman
