Adminitrative Console times out
Hello all,
I have a weird issue that I haven't found an answer to, I can open the administrative console, but after 2-3 minutes it appears to time out.
I get a red flag in the lower left, file/exit works, the rest are not select-able and the icons are grayed out.
The tabs work, but doesn't change anything.
I can still modify settings, programs, and other items, but can only do it in the 2-3 minute window. I tried a couple other tricks others have posted, but no dice so far.
ISY 99ri/IR Pro (1110)
Insteon_UD994 v.4.7.3 (2018-07-09-16:44:35)
PLM 44.D3.19 v9E / Connected
Java v8 Update 181
Windows 10 Pro Version 1803
Any ideas?
Steven
1 hour ago, sarness said:
Hello all,
Java v8 Update 181
Any ideas?
Steven
Which version of the UI are you using, or are you using the ISY Launcher?
It's also possible that your firewall may be blocking the admin console.
Edited by Techman
I'm using the ISY launcher, I've checked the firewall, no issues on that end, I did have a problem with DNS last month which I thought was causing the issue, but that has since been resolved.
At this point it's probably best to submit a ticket to UDI
Submit a Ticket:     http://www.universal-devices.com/contact-support
