ISY & SmartThings together?
I bought a Schlage zwave lock.  Is it possible to have the ISY and Smartthings on the same network?  My lock is far away from my ISY, and I really don’t feel like relocating it.  I added the lock to the SmartThings Hub, but was wondering if the ISY and Smartthings would talk to each other to extend the range.
I don't know about smartThings hub, but if you want the ISY to talk to the Schlage, why not put some sires to grow your z wave network?
That is what I did, love the Schlage on the ISY.
Sent from my SM-G955U using Tapatalk
Can you unlock it from the ISY?  I want to be able to use Google Assistant to unlock it with voice, which it doesn’t allow right now
Yes you can lock it, unlock it. I get a message from the isy letting me know who opened the door. I have a program that also will lock it if unlocked longer than 10 minutes.
Hmmm.  Maybe I’ll relocate the ISY and see if that works before getting another zwave device
Well that worked pretty easily, though I did have to remove the switch from zwave or something. Did you write a script for the notification?
I will share tonight when I get home.
Emily Front Door Code - [ID 001F][Parent 0025]
        'Door Locks / Front Door' User Number is 2
        Send Notification to 'Rebbeca' content 'Front Door Emily'
        Send Notification to 'Default' content 'Front Door Emily'
        Send Notification to 'Emily Butao' content 'Front Door Emily'
