Make ISY devices appear as hue bulbs
Sense energy monitor supports adding a hue bridge so you can control devices from the monitor.
I know there are hue emulator bridges but is there anything that will present isy994 devices as hue devices to the network?
  • 1 year later...
I see you have sensemonitoring. I installed the nodeserver but it does not connect The log displays.
2020-02-05 22:20:13,928 [MainThread] [INFO ] UDI Polyglot v2 Interface 2.0.34 Starting...
2020-02-05 22:20:13,933 [MainThread] [ERROR] Traceback (most recent call last):
2020-02-05 22:20:13,934 [MainThread] [ERROR] File "./sense_poly.py", line 13, in <module>
2020-02-05 22:20:13,936 [MainThread] [ERROR] from sense_energy import Senseable
2020-02-05 22:20:13,936 [MainThread] [ERROR] ModuleNotFoundError
2020-02-05 22:20:13,938 [MainThread] [ERROR] No module named 'sense_energy'
2020-02-05 22:22:02,813 [MainThread] [INFO ] Received Config from STDIN.
2020-02-05 22:22:02,815 [MainThread] [INFO ] UDI Polyglot v2 Interface 2.0.34 Starting...
2020-02-05 22:22:02,817 [MainThread] [ERROR] Traceback (most recent call last):
2020-02-05 22:22:02,818 [MainThread] [ERROR] File "./sense_poly.py", line 13, in <module>
2020-02-05 22:22:02,819 [MainThread] [ERROR] from sense_energy import Senseable
2020-02-05 22:22:02,820 [MainThread] [ERROR] ModuleNotFoundError
2020-02-05 22:22:02,820 [MainThread] [ERROR] No module named 'sense_energy'
I suspect that I have to set some keys in configuration.
Could you help me and tell what should one  enter in Custom Configuration Parameters
Mine is empty right now.
