Variable & Program help
I have a kitchen light (2466DW) and a sink light (2474DWH).  I want to switch the kitchen light on if I press The sink light on three times.  I made a variable $KLCount and the following programs:
Upcount (Works)
Control 'SinkLight' is switched On
$KLCount += 1
CountReset (Works)
if
Control 'SinkLight' is switched off
or Control 'KitchenLight' is switched off
$KLCount = 0
KLOn (Not Working)
$KLCount >= 3
Set 'KitchenLight' on
Wait 2 seconds
$KLCount =0
So as I've indicated it seems everything is working except when it come to turning the kitchen light on (The counter will go over three and the light will not come on and counter will not reset unless I turn one of the switches off.
Any ideas as to why this won't work??  Thanks for any help you can provide
Put the logic to turn on the light in your first program, something like this:
IF
   Control 'SinkLight' is switched on
and $KLCount >= 3
  wait 2 seconds
  $klCount =0
else
 KLCount +=1
The other thing to try is a state variable, I think those will activate a program, while a change in an integer var does not?
if $KLCount >= 3
Then $OnFlag = 1
IF
and $KLCount >= 3
  wait 2 seconds
  $klCount =0
else
 KLCount +=1
Yep That worked...will try messing with state variables at another time
Thanks again
