Insteon Controller & Responder Question
I can manually connect my insteon devices to be both controller & responders, and it shows up perfectly within ISY console.  I can't seem to find out how to add devices via the ISY console to be both controller & responder.  I add the device as controller to a scene, works fine - then I go back and try to add again as a resonder, no go.  Says already in scene.  Yet, as I already mentioned, I can go manually and link devices together as controller and responder and it works and looks perfectly under the ISY console.
Any help would be great!
Edited by cfluser
For example with a 2477D added to a Scene as a Controller only:
When you click on the Scene ‘itself’ you should see, on the lower right hand side of the screen, the device and it’s settings as as a Responder.
When you make changes to these settings, then when the device is toggled ON these settings become active.
Edited by LarryM
When you are using an ISY994i. Do not use manual linking of modules. Allow the ISY994i to do everything.
Also a good idea to do a Factory Reset on all new modules before using them. Test links are sometimes in a module from the factory and it can cause issues.
Edited by Brian H
And, do a factory reset on your devices before proceeding to use them with the ISY.
