New user: cannot get ISY-99iPro to get an IP address
I just followed installation instructions for my new ISY 99iPro and have been unable to connect to it. I am using:
WindowsXP Pro
Linksys WRT610N router
Norton Internet Security Firewall
I have verified:
UPnP is installed on my WinXP machine
UPnP is enabled on the router
I have completed turned off Norton Firewall.
As I debugged, I eventually discovered that my routers DHCP Client table did not indicate that the ISY had even obtained an IP address. I have rebooted everything a few times.
The only lights on the ISY is the PWR light & the Network lights.
Any suggestions/
Do you have a serial cable? If so, as a test you might want to login to your ISY and assign it a static IP address.
Here is a page with some assistance:
http://www.universal-devices.com/mwiki/ ... erial_Port
If you are able to assign it an IP address and access it via a web browser we'll be able to narrow down the issue a bit.
Let me know.
I think I may have a faulty ISY b/c while I was able to connect via serial one time, I am not able to consistently connect. Sometimes I can see the ISY boot up output on the serial while other times it doesn't output anything. On one try, I received this output when I rebooted the ISY:
Unimplemented line-f opcode FMT =00 SR =2708 FS =00
Faulted PC = FFC00534D0:0200B220FMT =FMT =00
On another try:
Universal Devices NBUD-70-100 Monitor V1.0 Jun 13 2007 15:27:39
HELP for help
nb>2DFMT =06 SR =FD6A FS =0B
Faulted PC = 200007FC
D0:8BE988D2 00000004 00000041 FFC50005 35B7BB23 00000000 FFFF3CBC 8153C97D
A0:FFC01157 0206C309 FFC002E4 FFFFFFFC 0000002F 98B7FD6A 200007FC 200007F4
Waiting 2sec to start 'A' to abort
Error Checksum Fail
No Valid app
HELP for help
nb>
Is this a recently purchased unit from Smarthome? If so, I would contact them for quickest replacement.
Let me know.
