Motion Goes Full On
I have my outside lights go to 60% at sunset and off at 10PM. What I am trying to do is have them go to 100% for one minute if the motion sensor is activated, and then back to 60%. If the sensor is activated after 10PM until sunrise the lights should go to 100% and then go off. Any help?
This is an interesting problem to me. I've programmed my motion detector to do some different things depending on state, so I'll take a stab at this.
Several assumptions:
1) Motion detector set for default operation (insteon ON when triggered, OFF after default timeout of 1 minute)
2) Scene "outside-lights" has ON level of each light set at 100%, and scene "outside-lights-60" has ON levels set to 60%
This approach uses three programs, one for each light level. The motion detector is not linked to anything other than the ISY:
60%
       Time is Sunset
    Or (
            From    Sunset
            To      10:00:00PM (same day)
        And Control 'motion-Sensor' is switched Off
       Set Scene 'outside-lights-60' On
ON
       From    Sunset
       To      Sunrise (next day)
   And Control 'motion-Sensor' is switched On
       Set Scene 'outside-lights' On
OFF
       From    10:00:00PM
       To      Sunset  (next day)
       Set Scene 'outside-lights' Off
I hope this helps triggers more ideas.
I can speak conceptually at this point, but my suggestion would be to create two program folders.... one to activate from sunset to 1000 and the other from 1000 to sunrise. In the first folder have two programs. One to turn it up to 60% at sunset (or a few seconds after), and the second to respond to the motion detector to full on, wait one minute, then back to 60%. In the second folder, start with a program to turn the light off at 1001 (to account for the possibility the the light was on the 1 minute full on condition. A second program would respond to the motion sensor like the other program, except turning if off after a minute.
I can see a minor chance of issues during the change from one folder to the other, but a bit more thought about using some conditions would solve that. I will think more when I get some time.
Oops. I see I forgot a condition in the OFF program I posted above, to turn the lights off at 10pm. The conditions above should be ORed with the following, similar to the 60% program:
Time is 10:00:00PM
There is still a problem with the light being on less than one minute if motion is detected in the minute prior to 10pm.
I wanted to offer more thoughts and suggestions. I suggest two folders, the first like this:
       From    Sunset
The second program folder like this:
       From    10:00:00PM
In the first folder would be two programs:
       Time is Sunset  +  2 seconds
       Set "outside lights' 60%
The second program in the first folder would be:
       Control 'motion sensor' is switched On
       Set 'outside lights' On
       Wait 1 minute
       Set 'outside light' 60%
I added a couple seconds to the on time, simply because I was not sure how the ISY handles the folder start time and program start time being the same. It may not be necessary. If this works as I believe it would, then between sunset and 10p, these two programs would produce the desired result. To the second folder, for the hours between 10p and sunrise, I would add the following two programs
       Control ' motion sensor' is switched On
       Wait  1 minute
       Set 'outside lights' Off
and
       Time is 10:01:00PM
I make the turn-off time to be 1001, just in case the light was triggered on right at 1000. I figure this is close enough
Thanks for you help. Your suggestions help me develop a solution. Thanks again :D:D
