Does ISY has a plugin system?
Hi,
I am a Homeseer user. There is a homeseer plugin the connect to the isy system.
I was sure I saw somewhere a list a plugin for the ISY sytem. But now, iI not find it .
If there such a plugin list somewhere?
thanks
I used Homeseer for X10. They had/have an Insteon plug-in.
I don't recall an ISY plug-in. A third party may have created one at some time.
WHat other technologies are you trying to integrate?
  • 4 weeks later...
I use HS3 and the plugin is called ISYInsteon...but you can also use zwave from the ISY.
I have used about every controller known to man over the last 5 years, and I highly recommend using HS3 instead of the HS2 <--> ISY plugin.
MUCH easier and far more advanced than the ISY implementation...let the hating begin : )
On 12/12/2018 at 6:46 PM, mattl0 said:
Hi,
thanks
@mattl0 are you looking for a HS3 -> ISY plugin or are you looking for a list of plugins for ISY?  I'm still learning ISY but instead of plugins they have "nodeservers"?  Keep in mind that the ISY "nodeserver" has nothing to do with node.js or Node-RED it's a ISY naming as "devices" are "nodes" in ISY???  Correct me if wrong people I'm still learning (I don't even have my ISY yet... in the mail)
