PLEASE READ when upgrading from older ISY firmware (pre 2.7)
Please review the following additional notes when upgrading from older ISY firmware (pre-2.7) to current releases:
- Users running firmware 2.6.1 should take a separate export of their Programs, alongside their normal backup, before running a firmware upgrade.
- Browser bookmarks to the ISY and Admin Console created while running older ISY firmware versions may not work with newer firmware versions due to URL changes. Please be sure to update your shortcuts accordingly after upgrading your firmware.
- Please note that firmware releases 2.6.1 and above now use default HTTP and HTTTPS ports (80 and 443, respectively). If you are running ISY-26 release 2.6 or ISY-99 release 1.0.0, please DISABLE internet access before this firmware upgrade, then re-enable once the upgrade is complete.
- ISY-26 owners running older firmware versions should upgrade to release 2.6.5 ( http://forum.universal-devices.com/viewtopic.php?t=1409 ) before upgrading to current releases.
SPECIAL UPDATE INSTRUCTIONS FOR ISY-26 OWNERS RUNNING FIRMWARE 2.6.8 THROUGH 2.6.15
As always, PLEASE be sure to have a good backup of your ISY before proceeding.
ISY-26 owners running firmware versions 2.6.8 through 2.6.15 will need to install temporary firmware 2.6.0 before upgrading to current releases. Please follow the steps below to complete your upgrade:
- download and save 2.6.0 from http://www.universal-devices.com/update ... nsteon.zip
(PLEASE DO NOT UNZIP)
- when prompted, use:
USERNAME: isy
PASSWORD: autoupdate
- login to Admin Console
- choose HELP, MANUALLY UPGRADE MY LIGHTING and choose the 2.6.0 file downloaded in the previous step
- wait for your ISY to reboot, RX and TX lights will be on (this is normal)
- download and save the current firmware release (PLEASE DO NOT UNZIP)
- login to your Admin Console using the following URL: http://www.universal-devices.com/99i
- choose HELP, MANUALLY UPGRADE MY LIGHTING, and choose the firmware file downloaded in the previous step
