2019 Update - version 3.6
madmartian
Improved Programs support:
Before: you could enable, disable, and run either leg of a program, but the display would only show enabled or disabled - if you clicked RUN it would run but the display would show no change, which was a tad confusing.
After: Now there are three indicators for programs instead of two - enabled, disabled, and ran. The icons have switched places a bit - enabled is now the black star, ran is the white star (same color as ON for other devices), and disabled is a circle with a line through it.
Note: since SHC conserves battery by not doing auto-updates, the "ran" state will show until a refresh.
Addition to dim levels:
There is now a 5% option for those wanting more granular control (with LED for example). I may at some point alter dimming to work better with LED lights whose dimming is not linear, but that is more of a long-term change I haven't made yet. Note that by adding an extra dim level, your saved dim level will be off by one level. Example: if your saved dim level was 20% it will now be 15%. You can fix this by setting it back to 20%. This is because the program saves the level, not the %, and I added a level at the bottom.
Bug fix: first time run had wonky sizing
Something you would only see on first run, which is why I missed it for so long - the first time the program was run, the fonts would be the wrong size in relation to the space and would be cut off at the bottom. One tap of the <FONT> controls would fix this forever. Now the first run no longer has that issue.
Please let me know if you experience any issues with the new version. I do not have an Android Pie device for testing yet. Please let me know if you run this successfully on a Pie phone (such as Pixel 3).
      37.6k
      376k
