JAVA Update changes to login
I have recently upgraded to the newest version of Java.  The shortcuts to ISY launcher no longer work.  Is there an easy way to set them up again?
Follow these instructions which will delete your shortcut and reinstall the launcher. It's possible that your security prompts were reset when you updated java.
Be sure to clear the java cache including installed applications
