Insteon Appliance switch/outlet for water heater and well pump
I like the idea of being able to set up ISY to turn off my 220v electric water heaters and my 220v water well pump in the event that moisture is detected on my mechanical room floor.  I see the Insteon 2477SA is discontinued? Anyone know why?  I guess there are a few still for sale out there.  I also discovered this product: https://innovativehomesys.com/collections/b-wired-in-devices/products/heavy-duty-208-240v-load-controller?variant=8125838196856 which appears to be third party load controller that they modified by installing an Insteon switch. They also make one with an Insteon outlet.
What do you guy think about the product I linked? Do you have any other/better ideas for turning off an electric water heater and well water pump remotely and with the use of an Insteon water sensor switch?
Edited by stealle
Another module that may assist you is an ELK 9200. It has a heavy duty 30 amp relay in it and can control a 220 volt load. Has a 120 volt coil and a standard AC cord on it. Controlled by an Insteon On/Off plug in module or another protocol like the old X10 Appliance Module.
https://www.elkproducts.com/product-catalog/elk-9200-heavy-duty-relay-contactor
Smarthome and other vendors do carry them. https://www.smarthome.com/elk-heavy-duty-relay-contactor-in-a-lockable-metal-structured-wiring-panel-enclosure.html
The product you linked to. Looks interesting. Not much data on if it has relays in it or some AC Solid State Relays.
I'm in the process of hooking up my air compressor in a similar fashion. I'm going to use one of the Insteon DIN rail on/off modules (2453-222) to trigger a 110 vac coil DIN rail contactor.
Edited by adamthp
