Another motion (MSII) Program question
Here are the programs.  Why is this turning Off when people are in the Kitchen and moving around?
Configuration:
MSII - On-Only linked to a KPL 6 button
Kitchen.Lights-State - [ID 002B][Parent 0018]
        'Kitchen / Motion Sensor / Kitchen.1 Motion' is switched On
        $Kitchen_Motion_State  = 1
        Wait  5 minutes
        $Kitchen_Motion_State  = 0
Kitchen Lights - Off - [ID 0011][Parent 0018]
        $Kitchen_Motion_State is 0
        Wait  5 minutes
        Set 'Kitchen / KPL6 / Kitchen.KPL6.1' Off
People can be in the Kitchen and moving around and the lights turn off.... ???
One would presume that it's because the motion sensor is not repeatedly sending the "on" signal when people are moving about -- rather, it simply does not send the "off" signal until it determines that motion has ceased.  Check the diagnostic log, at level 3, to see what's being sent by the motion sensor as you test the scenario.
I would guess that you might get the results you're looking for if you implemented the following logic:
  a) When the motion sensor sends an "On" signal, turn on the lights and stop the timer, if it's running.
  b) When the motion sensor status switches to "Off", start the timer.
  c) When the timer expires, turn off the lights.
Edited by mwester
clarification with diagnostics
