Changes to state variable in log?
If I run the "Then" clause to the following program should all the changes to the state variable "sTemp" show up in the log?
Test - [ID 0020][Parent 0001]
        $sTemp  = 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
        $sTemp += 1
As you reported in another thread, the changes show up in the Event Viewer.  I can confirm that I don't see the variable changes in my log.  One thing to keep in mind, though, is that only a change to the variable appears in the Event Viewer.  So if the THEN merely did $sTemp = 1 and you ran the THEN three times in a row, you would only see the first variable assignment in the Event Viewer and not the following two.  That is why when I use a state variable to track program execution, I assign a value that I'm tracking and then immediately assign 0 (i.e. $sTemp = 1 followed by $sTemp = 0).
