March 13, 20197 yr In the Admin console under main Ecobee thermostat, I can see it's getting all the info. Temps are correct, Heat/cool state, etc. The problem is when I go and try and change the mode (or any thing else) from the drop down to "Off", nothing happens and after a few seconds, the dropdown goes back to Auto. (the same thing happens for any of the other things with dropdowns). Any idea why I can't change these things?
March 13, 20197 yr More info would help. What OS and setup? A log file? Did it ever work? If not check your ip/port in ISY's node server config and make sure there's no firewall issue.
